| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#231 |
vicol-audio.ro
LME49713 is a very good choice in this regard.
Regards, Tibi |
#232 |
it depends on the DAC chip used
#233 |
Tolu, I put some sch with 861 AD, for Ibuffer, and tube out at the EC-design topic,
but I dont know on which page..? i tryed... pages around 100... I think sorry
#234 |
or transistor OP versions,
google for Sonic Sculptor Cheers
#235 |
Hello,
I'm modding Musical Fidelity V-Dac and have AD OP467 and National LME49740. Who is better choice for I/V conversion. Regards |
#236 |
"The output stage is 4 x NE 5534 and after which the DC block by 2 x 10uF Solen Fast Cap"
ccschua, You will get a big improvement by changing the 10uf solens to a better film cap; sonicaps or the more expansive sonicaps will sound much better if you are going to stay with that current oputput configuration. Cheers. |
#237 |
IMO, the easiest way to get good sound is to use OPA627BM or OPA627SM as I/V.
I won't say they are the best. But they are easy to get, easy to use, and especially easy to sound good. I think one can simply apply these OPA627s and spend more time thinking about other improvements in a system. |
#238 |
a simple resistor is better as each OP-AMP that I know - please refer for the exactly value
http://www.dddac.de/pcm63/DAC_I-V_Resistor.htm (easy to realize for check out the sound quality) for ultimate sound quality you need the I/U converter from Papa Nelson Pass - please refer in this case therefore the follow URLs: A nice dac to complement the Aleph-X. http://calab.kaist.ac.kr/~cgkim/audi....com/d1_ua.htm Anyone built a Pass D1 I/V for a TI1794 or TI1794 DAC? http://www.head-fi.org/forums/f6/pas...ne-kit-324197/ http://www.head-case.org/forums/do-y...-d1-clone.html Until this day I haven't discover an OP-Amp with similar sonic quality. For me it is amazing, that most of the hobby and commercial developers don't use this solution |
#239 |
Well there is a reason why you should choose an active part with as little input impedance as possible. The current outputs from a dac is far from linear. They are only linear in a very narrow band.
But then again. This I/V converter can be made with current mirror and an output buffer with no feedback and the sonic performance will not suffer.... And in bonus you will get a far better performance than with resistors alone Ask Jocko Homo if he still is arround here.... - Sonny |
#240 |
diyAudio Moderator Emeritus
Jocko is not around here. He is busy at the other website.
It's only audio |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 03:15 PM |
| RCA conversion | oogared | Instruments and Amps | 1 | 1st September 2005 10:31 PM |
| Regulate the psu of a power opamp with a similar power opamp? | Franz G | Chip Amps | 34 | 19th October 2004 11:49 AM |
| D1.I/V conversion | nar | Pass Labs | 2 | 20th April 2002 11:46 AM |
| Page generated in 0.09607 seconds (82.17% PHP - 17.83% MySQL) with 11 queries |
