The Pass D1 For Tda1543
Old 30th January 2009, 08:16 AM   #61
anbello is offline anbello  Italy
anbello's Avatar
Hi stefanobilliani,
i would like to know if it's possible to use 2 o 4 tda1543 in parallel sharing the same i/v d1 stage (i mean the 4 i out of the dacs entering in 1 d1 stage).
Another question: the out of the d1 can directly drive the next stage (a pre or chipamp in my case) or needs some sort of buffering?
Andrea
Old 2nd February 2009, 09:33 AM   #62
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
anyone?
Old 2nd February 2009, 10:25 AM   #63
stefanobilliani is offline stefanobilliani  Italy
Originally posted by anbello
Hi stefanobilliani,
Andrea
Yes you can use that approach , you will need to change some values of resistance to make it work properly . Not sure if you will get improvements , the best thing is to try .
I remember I tryed 2 of them and they did work ok .
Regarding the output driving that there is not a problem at all unless you need more gain .
The output impedance is already low enough , of course I omitted in this thread the use of buffers for semplicity and also becouse , probably , the amps I play with are often buffered at theyr input ( see Zen V4 that includes the buffer at its input and inside the feedback loop ).
Old 2nd February 2009, 10:48 AM   #64
Hi Stefan,
any idea why mine doesnt play music?
Old 2nd February 2009, 01:05 PM   #65
How many 1543 are you using?
Old 2nd February 2009, 11:31 PM   #66
I am using 2, from the 74hc86 to the dacs is exactly as your schematic.
Old 3rd February 2009, 08:08 AM   #67
Ah ok , so you are doing balanced mode . I see you use the I/V resistor , you need 4 of them . Do this test: leve out the Xor ports and check if each Tda works in Single Ended mode . Control also the voltages at the PIN 6,7, 8 . and remember that with the Cascode I/V stage there is no need to control the pin 7( as shown in schematic posted) , while if you use I/V resistors that pin CANNOT be left alone , but there is the need to create a current through it with a resistor , typically 1k ohm or so to ground .
Old 3rd February 2009, 08:29 AM   #68
I also experimented to connect pin 7 ( and his resistance ) to a negative voltage , and had very nice results IMHO in terms of dynamics . I mean something like -30 volts .
Old 3rd February 2009, 08:54 AM   #69
Thanks Stefan,
Pin 7 (vref) is 1.5K, pins 6 and 8 is 2.7K.
I will try and bypass the Xor and try single ended tomorrow, its bed time. Thanks
Old 1st May 2009, 04:37 AM   #70
ChuckT is offline ChuckT
Hi Stef,
I am tempted to try the D1 but I have only +/-15V on hand, do I need to half the value for R1 and R2?
And what is the resistance from pin 7 to ground.
Thanks.
The Pass D1 For Tda1543Hide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
