The Pass D1 For Tda1543
Old 28th April 2004, 01:37 AM   #21
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
Very interesting project. Cheap, fully balanced and very compact.
Might be an interesting match for my version of D1 output stage, which measures 80x40 millimeters (stereo, balanced, single sided board):
Best regards: Holger
www.holgerbarske.com
Old 28th April 2004, 08:11 AM   #22
stefanobilliani is offline stefanobilliani  Italy
Originally posted by sparkle
how do You set this thing to work properly? I know that I should have 2 volts on input of the i/v and I know that it should be trimmed with VR1 but from which side do You start- from which value of the VR1. Regards
daniel
When you set the I/V stage first time, the TDA1543 is diconnected.
Trim the pot until you have 2,00 volts at the source , than you swich off the supply , and wait for discharge. Than connect the TDA to the I/V stage, power up both circuits and do the final trimming.
Old 28th April 2004, 08:26 AM   #23
Default Re: Re: Balnced Arrangement
Originally posted by guido
Two idea's for improvements:
reclock all the data with FF's: use '74 so you don't need inverters and reclock with the tentclock. You will loose jitter created by the 7310 (don't know the timingrelation between 7310 I2S out and it's clock input but it should be possible). Maybe you need to invert the clock to the 7310.
Second, obvious (coming from me ): split left and right into two
I2S streams and use one dac for left and one for right.
Greetings,
Reclock: first off , do you think I need 2 FF in series to do the reclock? or just one in sinchronous mode?
No inverters, no buffers? You know , it is just fiew days that the XOR buffers are working in the circuits and every time I change something in the set up is like to jump off the spring-board
And jitter is so underhand
What is the way of inverting clock? I re read your .pdf for the split LR version I admit it is interesting to me and I feel like I am close to the possibilty of making an effort like that, if you have a pcb of your work I will be interested for sure
Old 28th April 2004, 08:30 AM   #24
Default Re: Re: Re: Re: The Pass D1 For Tda1543
Originally posted by rfbrw
You are confusing the specific with the general.
...it is also true that the I/V stage does not amplifies current.
Old 28th April 2004, 08:41 AM   #25
Great , but probably the buffers has to be modified too. The source follower load resistor.
Old 28th April 2004, 08:56 AM   #26
sparkle is offline sparkle
sparkle's Avatar
HI!
Mr. Billiani - thanks You made my day .
I was allways wondering how to trim the active i/v ......none of my question were answered until now. Thanks again!
regards
daniel
edit:
HBarske- I can't see that You are using volume control like in d! service manual- if so- what is the maksimum output that You get out of it?
Old 28th April 2004, 09:09 AM   #27
Component values certainly will have to bei modified. The values above are the original ones.
Old 28th April 2004, 09:17 AM   #28
HI!
daniel
I am glad
As you see I considered the no-buffer option - if a preamp is used, of course- and works great before the BOSOZ.
cheers
Old 28th April 2004, 09:27 AM   #29
My suggestion refers to your idea in post #16, of course "no buffer" is an option.
Old 28th April 2004, 09:35 AM   #30
sparkle's Avatar
Hi!
One more- did somebody tried to trim the original schematic from D1 from Mr. Pass to 2V or little more to make it suitable for our TDA1543?
regards
daniel
The Pass D1 For Tda1543Hide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
