lingDAC - cost effective RBCD multibit DAC design
Old 12th July 2018, 04:07 PM   #11
sumotan is online now sumotan  Indonesia
Congrats Abrax,
Im an old man, soldering those smd parts is going to kill me. Lol
Old 12th July 2018, 05:01 PM   #12
wcwc is offline wcwc  United States
Looks interesting.
Old 12th July 2018, 05:50 PM   #13
rickmcinnis is offline rickmcinnis  United States
Originally Posted by sumotan View Post
Congrats Abrax,
I am hoping he might find a way to offer populated boards!!!
(thanks for your note sumotan - still trying to figure out which way to go - but have long wanted to try something from the mind of abraxalito)
Rick McInnis
Old 12th July 2018, 05:52 PM   #14
HEARING forward to reading Randy's assessment.
Rick McInnis
Old 12th July 2018, 05:54 PM   #15
GORDMUS68 is offline GORDMUS68  South Africa
Very fortunate to have received one the first version three tier boards with SE output a while back, and also only recently had time to give the boards a quick try. Yes feeling very guilty about getting around to this after a few months - humble apologies Abrax.
Have been putting together a battery supply using Lipo with regulators when time permits between daily grind of course.
For the first 'armature' effort, read ''could no longer wait', I used two Lipo in series which gave me between 7.98 and settling at 7.54 volts for a quick whirl.
The sound quality did not seem to degrade between the two voltages.
What is the typical 'negative' effect to expect when the DAC is supplied at the lower threshold of the 8v (+/- 0,5v) 120ma?
Perhaps I should read a bit more - sorry if this a naive question!
Old 13th July 2018, 12:24 AM   #16
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Going below 7.5V what will happen is the transistor doing the supply regulation won't regulate any more. Whether anything is audible I don't know, haven't done tests.
Incidentally just a quick mention that the lingDAC picture I put up in post #3 is an updated version (v2) of the design, based on some feedback from you guys and doing my own listening. The five of you who've already got lingDACs have the v1. The biggest change is to the DAC board itself where I've reduced the number of DAC chips down to two and implemented a low-noise, low impedance shunt regulator. The shunt reg makes a substantial improvement to the bass, its by no means subtle.
v2 DAC board schematic added
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 13th July 2018, 07:21 AM   #17
Thanks Abrax - that gives me something to hunt and increase my limited but hopefully expanding understanding. Cheers
Old 13th July 2018, 01:46 PM   #18
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Richard, what is the intended function of LED5 through LED8, which are attached parallel to the analog outputs of inverted data DAC U8?
-Ken
Old 13th July 2018, 02:19 PM   #19
abraxalito's Avatar
Hi Ken - good question.
The aim there is to give the 'passive' DAC as close as possible the same voltage on its outputs as the active one. In the basic configuration only one DAC's outputs are taken to the I/V stage, the other DAC is there solely as a 'dummy' to balance out the current drawn by the active DAC (the current draw being signal dependent). I figured to get the best cancellation it might be best to give both DACs the same output voltage, but I've not actually gone and verified this.
With the original v1 lingDAC the outputs were held at +4.5V by the I/V stage, this necessitated two green LEDs in series (2.2V each) to get to the desired voltage. On v2 lingDAC the I/V stage holds the output around +1.1V - this needs a single IR LED, the other LED footprint will be fitted with a 0R link.
Old 13th July 2018, 02:58 PM   #20
randytsuch is offline randytsuch
Can the v1 be modded to a v2?
I'll compare schematics myself, and see how much difference there is.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
lingDAC - cost effective RBCD multibit DAC designHide this!Advertise here!
Extremely cost-effective and professional PCB Layout design service Kevmeister Vendor's Bazaar 0 30th June 2013 05:27 AM
Most cost effective way to store cd's jerryo Digital Source 9 31st December 2009 09:13 AM
Cost-effective audio cap relycap Vendor's Bazaar 0 27th September 2009 03:56 PM
Most cost effective active set up ? jerryo Class D 0 20th November 2007 03:56 PM
Cost effective upgrades Pan Solid State 4 9th April 2003 12:09 AM
