Plug-in replacement for TDA1541, using 4x TDA1387
Old 29th June 2018, 04:59 AM   #11
hollowman is offline hollowman  United States
hollowman's Avatar
Default Philips multi-bit DACs -- not R2R?
Originally Posted by sumotan View Post
Im always for R2R dac especially those like Philips ....
The following was recently posted on a ComputerAudiophile thread:
No Philips designed DACs are R2R -- that designation refers to a series of resistors controlled by switches. Philips used transistors as current sources though which gets around the glitchiness of the R2R approach. Rather than relying on matching of resistors Philips adopts an active DEM (dynamic element matching) approach, at least for part of the DAC array in the 1541, though not in the 1543 as that's the economy device.
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 11th July 2018, 11:18 AM   #12
schillg11 is offline schillg11  Germany
Originally Posted by poynton View Post
The module is a drop-in replacement for a TDA1541A.
I have used it to replace a TDA1541A S1 in my Revox B226.
I found greater transparency and better bass.
There are also available 8x TDA1387 modules available for not much more money.
I have some but have yet to try them.
Andy
Hi Andi,
i make this module
HIFI 8PCS TDA1387 In Parallel Module Replacement Substitution TDA1541 TDA1541A D | eBay
also work in my Marantz CD583 as direct replacement without any modifications.I can conform that the bass is more punchy. So it seems to be a cheap alternative (€6 incl. shipment) for the TDA1541A.
BR
Günni
Plug-in replacement for TDA1541, using 4x TDA1387Hide this!Advertise here!
Efficiency gains from dust cap removal/phase plug replacement altie Multi-Way 10 14th October 2017 11:17 PM
70's Pionner RCA plug replacement mgallon32 Solid State 3 2nd September 2015 11:23 AM
Shure E2C-N Plug Replacement MilesCampbell Headphone Systems 0 14th June 2011 08:49 PM
tube rectifier plug in s-s replacement pforeman Tubes / Valves 5 2nd June 2009 11:50 PM
TDA1541/SAA7220 replacement board Jocko Homo Swap Meet 12 20th December 2003 12:53 PM
