Moving from 9038Q2M to a 9028Pro board
Old 20th June 2018, 08:56 PM   #11
phase is offline phase  United States
Is this the same board that was referenced early on in the other 9038 thread?
I wondered why no one put up a link to it when it seemed to have a lot going for it...
Those purple elnas arenít helping you, discovered that on a similar dac here recently, and if you can manage to get a COG .1uf for the clock, that will help a lot also.
Iíve been pretty happy with the lt1963 so far.
Old 20th June 2018, 08:58 PM   #12
Markw4 is offline Markw4  United States
There are likely separate AVCC filter caps for each channel. Should be.
Old 20th June 2018, 08:59 PM   #13
Mikett is offline Mikett  Canada
The challenge is that the first decoupling cap leading from the AVCC LT1963 then feeds to other decoupling caps closer to the DAC via an inner layer. At those points, the designers feed from there to the two AVCC resistor divider circuits via a surface trace layer on the board. So the challenge is to cut off the feed from the first cap to the other caps...inside the board.
Old 20th June 2018, 09:00 PM   #14
Yes, there is.
Old 20th June 2018, 09:02 PM   #15
How about removing the resistor dividers and tossing them? Run new wires above board to the pads. ... Although, it doesn't make sense to have resistors last, should be caps last before the AVCC pins.
Old 20th June 2018, 09:04 PM   #16
Those purple elnas aren’t helping you, discovered that on a similar dac here recently, and if you can manage to get a COG .1uf for the clock, that will help a lot also.
I’ve been pretty happy with the lt1963 so far.
Are you referencing the SilmicIIs? The burgundy ones are SilmicIIs. The lighter color ones are 33uF Sanyo oscons.
Old 20th June 2018, 09:08 PM   #17
Yeah there caps before the AVCC pins but they are connected inside the layer to the LT1963. So essentially the L&R AVCC feed branch out inside the board.
Old 20th June 2018, 09:10 PM   #18
Then what was that about divider resistors?
Old 20th June 2018, 09:13 PM   #19
Right at the IV stage AVCC/2.
Old 20th June 2018, 09:20 PM   #20
Divider 4.7 K - 4.7K
Moving from 9038Q2M to a 9028Pro boardHide this!Advertise here!
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry Pi iancanada PC Based 587 8th July 2018 10:23 PM
Moving day jackinnj The Lounge 12 26th January 2016 01:32 PM
Moving Pots from the PCB georgebrooke Construction Tips 10 15th September 2013 10:01 PM
The Hazards of Moving KBK Everything Else 1 2nd February 2004 10:44 AM
