Changing output capacitors on a D2 dac
Hi there, I am not a tech expert so I am asking here if there is any advantage changing out the 2 output capacitors Wima 1.5uf 160v with Jantzen superior 2.2uf 800v capacitors. The caps are on the output and that is all I know. Will it improve the sound somewhat? Any help is greatly appreciated Russell
If you Wimas are polyester type (MKS) you do well changing them with polypropylens (PP) like the Jantzens you stated. If your Wimas are PP (MKP) then it's system dependent what difference you will hear. Anyway Superiors are a good value caps, if you don't to spend an arm and a leg for those kind of things, go ahead
