Linkwitz-Riley 12 db line level calculation
Old 19th March 2018, 07:51 PM   #21
MarcelvdG is offline MarcelvdG  Netherlands
Originally Posted by scott68 View Post
Oh, didn't explain myself completely - I meant not C1 or C2 but the numbers below them 1 and 2?
Probably pin numbers, some schematic drawing programs assign pin numbers to all components. Please ignore them.
Old 19th March 2018, 08:00 PM   #22
No I don't play church music or synthesizer at all.
The reason I asked is that I wonder how useful the 50 Hz high-pass will be. Due to the constraint that it should only consist of Rs and Cs, it has a very smooth roll-off and only gives a good suppression at frequencies far below 50 Hz (a 50 Hz first-order high-pass is roughly at -7 dB at 25 Hz, -3 dB at 50 Hz and -1 dB at 100 Hz). Some typical sources of frequencies far below 50 Hz are church organs, synthesizers, warped records and audiophile live recordings made outside or in a place with a draft. Anyway, you can try and see.
Old 19th March 2018, 08:48 PM   #23
scott68 is offline scott68  United States
I hadn't thought about that - I just assumed it would allow me to increase the volume without lower Hz causing problems- I'll try it anyway with a switch and see if it makes any perceivable difference above and below 50.
Which do you think would be the better approach to take a stereo signal and make a mono signal before your circuit as there seems to be several approaches that I have researched from the internet?
1. make "Y" with a 4.7k resistor on each arm before into the single leg.
Or 2. a suggested resistance of 10% of the amplifier input impedance which in my case would be anywhere from 1.3K to 3.6K
or 3. or 1k (headphone output ) to 5K (Line output).
On my full range (right channel) , if I want to lower the volume to match the woofer output, could I place a log/tapered pot after the mono resistors above and before your circuit. If so, what size, ie, 5k, 10K, 20 K or ?
Would another pot be able to vary the cutoff, ie from 100 to 200 hz vs your circuit 150 hz cutoff? If so , what size and where to place in your circuit?
Old 19th March 2018, 09:17 PM   #24
None, because the stereo to mono conversion is already included in my circuit. In the schematic in post #14, the 390 ohm resistors take care of that for the woofer and the 47 ohm resistors and 2.7 uF capacitors for the full-range channel. At the same time they also filter.
At the output of the lower branch of the circuit (the high-pass part of the crossover filter), you could change the 1 kohm resistor to ground into a 1.2 kohm resistor and shunt it with a 5 kohm potmeter that drives the right channel of the amplifier.
No, you would need five ganged potmeters with different values for that. That doesn't sound very practical.
Last edited by MarcelvdG; 19th March 2018 at 09:26 PM. Reason: 5 kohm potmeter with 1.2 kohm resistor is better than 20 kohm potmeter with 1 kohm resistor.
Old 20th March 2018, 12:29 AM   #25
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Yes they are pin numbers for the CAD system.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Linkwitz-Riley 12 db line level calculationHide this!Advertise here!
line level attenuator calculation Edwardb Analog Line Level 46 18th January 2017 10:29 PM
Butterworth series to Linkwitz-Riley Calculation Hearinspace Analog Line Level 18 26th July 2016 09:42 AM
Linkwitz-Riley 24 dB/Octave pcb tonitonitoni Analog Line Level 4 13th March 2015 04:07 PM
linkwitz riley crossover davidel94 Multi-Way 12 29th September 2012 10:46 PM
A Challenge to Linkwitz-Riley ? jackinnj Multi-Way 17 14th March 2006 11:50 PM
