Best Op-amps for Behringer DCX2496?
I presume that the current opamps are smt NRC4580s. I really wouldn't suggest any fancy, superfast opamps (newer ADs, LM6172, etc) given the potential noise on the smps power supply and from the digital devices everywhere. I changed my opamps to opa2132. The desoldering is no fun.
There are several parts in there that are unsuited for a cost-no-object modification.
I would advice that you consider building a complete DAC/output filter from scratch. I am currently getting started on this.
It is not all that hard since you don't need to build the full DAC with input receivers etc.
Petter
RE: op amps
Three suggestions :).
1. Expensive one : use 2*OPA627 instead of NE4580/JRC4580/NJM4580 with such kind of adapter http://www.referenceaudiomods.com/images/products/audiocom/opamp627_s.jpg
This is the best solution, IMO.
2. Significantly less expensive, but still worth to use - if your 4580 are SOIC, that without any problem, if they are DIP (most probably), use SOIC->DIP adapter, as this one, for example: http://members.cox.net/alexhardware/images/AD797.JPG
and op amps AD8066 ... if your supply voltage is <12V even better solution is AD8620 ...
3. OPA2134 is a bit better then OPA2132 (IMO), having almost the same parameters, but being specifically designed for audio applications, as stated in TI Audio solution guide (AFAIK it means more even harmonics, then odd, but I am not sure 100% - at least in the specifications for "audio" op amps one can find the graph for 2nd harmonics and 3rd instead of the common THD vs frequency graph, which doesn't separate even and odd harmonics).
Another point - in some schematics OPA2134 can oscillate, where OPA2132 will still be stable ... as stated here:
http://tangentsoft.net/audio/opamps.html
I haven't been able to see OPA2134 oscillating though ...
We have to know that OPA2134 has 5 times more distortions at the high frequencies then OPA627:
http://www.dself.dsl.pipex.com/ampins/webbop/2134.htm
http://www.dself.dsl.pipex.com/ampins/webbop/opa627.htm
Though both of them - OPA1234 and OPA2132 are still claimed by some extreme modders "on the list of shame":
http://shop.store.yahoo.com/yhst-9053161298275/opamps.html
The Op Amp list of shame: NJM5532, NE5532, LM318, OPA2134, NJM2114, NJM4558, NJM4560, OPA2132, AD827, OPA2604, LF353, OP275, OP275, AD712
But IMO OPA2134/OPA2132 are not the best, but still superior in comparison with 4580, the spectrum of the last one has a lot of higher harmonics, IMO the reason of "artificial" sounding ... http://bono-www.ss.titech.ac.jp/~hajime/uec/distortion/opa/4580_f.gif
The good article about higher harmonics in op amps and advices in selection of them is here:
http://headwize.com/projects/showfile.php?file=opamp_prj.htm
Re: Maybe AD8066?
Greggan said:
Have anyone tryed this one??
it is a sister to AD8065 witch is higly regarded acording to LC audio www.lcaudio.com
You can't.
DCX and DEQ use +/-15V. AD chips need 12/13V max.
We successfuly installed OPA2604 (output) and OPA2134 (input) inside a DCX. I personaly have OPA264AU inside my DEQ.
This is difficult to do. You must have the right equipements to unsolder and solder SIOC chips. The circuit board is realy fragile.
7 chips to change in the DEQ. 17 chips to change in the DCX.
Good luke.
