A story of mysterious interaction between a diy tda1543 dac setup and the human body.
Old 21st March 2018, 02:16 AM   #21
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Yeah that's the circuit I was thinking of. Pin5 can be 8V with TDA1543, on TDA1387 you'll likely destroy the chip. If using 8V on 1543, you'll want the TL431 to set a higher voltage, about 6V.
For 16X parallel it would work too, just lower the 1k1 suitably to cope with 16*2.3mA for the current swing.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 21st March 2018, 03:54 AM   #22
Bartb is offline Bartb  Slovenia
It seems to me the TDA1543 is indestructible
Once I placed it in the socket wrong way and left it sucking 1A for minutes. Checked the temperature and got a blister. Worked perfectly afterwards!
(1K1 16 should do...)
I'll try this circuit and let you know asap. Thanks!
Old 3rd April 2018, 09:14 PM   #23
Hello Abraxalito,
received components and starting assembly of the active stage you suggested.
Trying out a single TDA1543 to keep things simple (for now).
Can you remove my doubt about pin7 (Vref) : still goes to ground with 1.5K, correct ?
Thanks B.
Old 4th April 2018, 03:46 AM   #24
abraxalito's Avatar
You're using the single transistor I/V on TDA1543? In which case yes you need some bias (by a R on pin7) just as before. But you can get better sound by using your own supplied current source rather than using the one internal to the 1543.
Old 4th April 2018, 09:50 AM   #25
Yes ! I'm wiring up the schematic you suggested here
(Single PNP transistor in common-base mode.):
Please help: nOOb building a 9028 DAC
My own supply current you say ? I'll do it. Can you give me more details on how to do it ? Thanks.
Old 4th April 2018, 10:36 AM   #26
abraxalito's Avatar
Right now, no I feel too lazy to draw a schematic. Use the resistor on pin7
I didn't say 'your own supply current' rather 'your own supplied current source'.
Old 4th April 2018, 11:53 AM   #27
Ok ok no worry I have abused of your patience already.
I will complete what is settled.
"There's plenty meat on the fire already"
Will have the desert later...
Thanks again !
Old 8th April 2018, 03:18 PM   #28
Hello Abraxalito,
I've built the circuit you suggested.
("Single PNP transistor in common-base mode. DAC output goes to emitter, I/V resistor between collector and 0V." for TDA1543)
It sounds divine !! Much better than the single TDA1543 or 24x TDA1543 with Output resistance to ground. Really appreciated the tip !
I'm only having this little trouble: It played fine for a few minutes, then there was a pop and it when virtually quiet. After testing for everything else I figured maybe there was trouble with the BC807. I replaced it and it played fine again! After a few mintes it went quiet again. (Attached are the components I'm using; After Ferrite Bead we have a healthy +3.79V)
What am I doing wrong ?
Old 8th April 2018, 03:43 PM   #29
abraxalito's Avatar
How are you generating the reference voltage to feed to the bases?
Its possible you've got oscillation - try putting 220ohm resistors between the Vref and the base of each transistor. I think my original schematic had a ferrite bead on the base but that's not enough to suppress oscillation in every condition.
Old 8th April 2018, 04:53 PM   #30
Hello !
I am strictly following your schematic (+3.8V from TL431, and pulling the +6V from the power supply - the same one feeding the TDA1543)
Yes! your original schematic has a ferrite bead on the base. I marked it red in my photo (too small?).
Ok I'll try the 220ohm asap ( and get some spare BC807s )
Thanks!
B.
A story of mysterious interaction between a diy tda1543 dac setup and the human body.Hide this!Advertise here!
Human body field correction device rellik The Lounge 35 25th May 2016 03:10 AM
Misterious Altec lookalike horns Zen Mod Multi-Way 12 15th January 2010 02:21 PM
Amp-Load interaction zeus_threat Solid State 26 18th June 2006 06:43 PM
Aleph CS and interaction with PS mchapman Pass Labs 2 5th June 2006 08:46 PM
TDA1543 setup (alternate I/V output) Rocky Digital Source 8 26th October 2005 01:35 PM
