I/V stage for ES9028Q2M
Old 7th February 2018, 04:53 AM   #1
gandolf is offline gandolf  United States
Question I/V stage for ES9028Q2M
I am trying to design an I/V stage for ES9028Q2M DAC. I was first considering the Zen style, using a common gate amplifier to present low impedance to the DAC. But soon I have encountered problems:
First, in order to really get low input impedance, the transistor needs to be biased to saturation region, this requires a certain amount of Vds (> Vgs-Vth), assume 4V. In addition, the bias current should be much larger than the DAC output current to make the DAC output a 'small signal' (keep the bias point stable). The ES9028Q2M can put 7mA out, the bias current of the common gate should be around 70mA. With 150R resistor, the voltage drop is 10.5V. The third one is the DAC output is NOT 0V, it is AVCC/2, 1.65V in my case. Thus the input common mode of the common gate should match this voltage. A resistor is not possible since the resistance will be limited and this will draw some of the DAC output currents to ground. An LDO may be the only solution. This further push the supply of the amplifier to as high as 16V. I would rather NOT to have such a high voltage rail around a mainly 3.3V circuit, let alone the required 2X LDOs for each channel.
Here is my question, why don't people use low noise high bandwidth fully differential amplifier from ADI or TI to implement the I/V stage? Like following:
For example, AD8138 from ADI is a nice amplifier. It has a 300MHz+ bandwidth, 1000+ V/us slew rate, very low noise, very low distortion, works with 3.3V single rail and adjustable input/output common mode. What is the drawback to using such an amplifier to implement the I/V stage?
Old 7th February 2018, 02:33 PM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
From a quick look at the datasheet, the 'very low noise' description only applies above the audio band. There does look to be rather a high noise corner frequency. In comparison to a discrete I/V stage, a disadvantage for an IC would be its classAB output stage, leading to noisy power supplies. Incidentally, to avoid the need for higher voltage rails you can adopt current source biassing for the common-gate transistor. This would allow only the signal current to pass through the I/V resistor rather than the whole of your 70mA.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 7th February 2018, 03:13 PM   #3
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
Can you give the link to the datasheet of that DAC chip?
The common I/V stage is a high speed OP.
Old 7th February 2018, 10:59 PM   #4
I still need an opamp as I want to keep the supply to 3.3V across the board. The entire supply would now enough to provide enough Vds for most MOSFET. After reviewing more opamps, I would like to use LT1819 instead the ADI one. It has 400MHz bandwidth, 2500V/us slew rate. Noise wise, 6nV/sqrt(Hz) after corner frequency and ~40nV/sqrt(Hz) at 100Hz, should be able to claim low noise this time.
Tentative schematic:
Transient simulation with 7mAp-p current input @1KHz:
AC simulation (Unity gain stable!!):
Old 7th February 2018, 11:00 PM   #5
I am sorry the datasheet is protected by NDA (ESS.....).
Yeap, I am trying to use an OP to implement my I/V
Old 8th February 2018, 12:59 AM   #6
quanghao is offline quanghao  Viet Nam
I/V stage for ES9028Q2M Send a message via Yahoo to quanghao I/V stage for ES9028Q2M
Hi gandolf!
Vcm you want = 0V?
Follow data off ESS Vcm i see the sample image
thanks
Old 8th February 2018, 02:11 AM   #7
Originally Posted by quanghao View Post
Hi gandolf!
Vcm you want = 0V?
thanks
No, Vcm should not be 0V.
Yes, in the actual circuit there will be several decaps at the Vcm node.
Old 8th February 2018, 02:26 AM   #8
please go up 150R to 2.2K to 10K and one cap to GND. i think 150R is low value!
thank
Old 8th February 2018, 02:36 AM   #9
thank
Thanks for the suggestion.
Old 8th February 2018, 04:01 AM   #10
DPH is offline DPH  United States
Gandolf, go look for something like the 9018 or 9016 Datasheet online, the spec design is essentially a LME49720 configured as I/V's, pretty much classic design.
Also, the parts you're suggesting aren't low noise at audio bandwidth, maybe something like the OPA1632, but feel free to simply use a dual opamp instead.
It's also not difficult to make a center-tap reference from a precision resistor divider and a capacitor (for stability). If you look for JensH's posts in one of the 9038q2m threads, he's got a circuit. Scott Wurcer threw in a nice general form (and some things to think about) for an I/V in the AD797 http://www.analog.com/media/en/techn...eets/AD797.pdf pg 17.
There's a bevy of ways to do this. A quick/but not ridiculously quick low-noise general purpose opamp would be excellent. If you want to go nuts, look at an OPA1612 or better ADA4898. Mind your layout though.
Happy DIYing, Daniel
I/V stage for ES9028Q2MHide this!Advertise here!
ES9028Q2M balanced output evert1 Digital Line Level 0 26th December 2017 01:30 PM
Phono stage design considerations part 1: choosing 1st stage tube Joshua_G Tubes / Valves 207 5th March 2016 12:07 PM
opamp plus driver stage and output stage with its own supply, what could happen? Mihkus Chip Amps 165 8th February 2014 11:14 AM
Adding a 3rd gain stage to an MM phono stage, to make it suitable for LOMC? andyr Analogue Source 10 16th August 2012 04:10 AM
2 stage Stereo/4 Stage Mono Triode Preamp with independent drive control & inverters sampleaccurate Tubes / Valves 10 9th March 2011 10:31 AM
