Go Back   Home > Forums > Source & Line > Digital Line Level
Old 14th April 2004, 10:48 PM   #61
guido is offline guido  Netherlands
guido's Avatar
And in the last (?) player with 1541A, pin 4 is connected to pin 2.
That's the Marantz CD7 with the "famous" TDA1541/A/N2 (double crown). They shurely were not preparing that player for the old 1541...
And the cap is .... 680pF.
Think a 680 cap must be cheaper than a 470 cap
So one could put a 1541 in (actually two )
Almost one again, must go zzzzzzzzzzzz
GuidoB
Old 14th April 2004, 10:51 PM   #62
guido's Avatar
Originally posted by zygibajt
Guido,
I have just read one of your older posts when you tried to exchange older M4804A chip in your CD 650 for SAA7210.
Did SAA7210 work as a direct replacement,or there were some diffrances?
I have the player with that old chip and have some spare SAA7210 to drop in.
Bartek
Think it worked as direct drop-in. The 4804 should have faults, but in my player i did not see/hear them. But i could not see if the components around it were different than the schematics i have with the 7210 (SMD). So not fully shure. Never found anything on that chip.
But in general, if it works, don't break it
GuidoB
Old 14th April 2004, 11:55 PM   #63
Bernhard's Avatar
Originally posted by guido
1541: pin 4 = SCK, no DEM cap
1541A pin 4 = nothing, DEM cap.
So 1541 in 1541A player
So 1541A in 1541 player should not work, since DEM cap is not
there.
Aren't we dutch some funny guys
I have the DEM cap in my CD304mkII too, and that was made for 1541.
Maybe they knew about the coming 1541A and put the cap there for chip upgrade.
Or the datasheet is wrong and there is no internal cap in the 1541.
I asked Mr. FLUKE about capacitance on pins 16 & 17 on both chips and he said that there isn't any.
So, if there is an internal cap in the 1541, it is not connected to the pins.
Another question regarding the 7220.
In the 304 there are two smd transistors around pin 21, in the cd650 it is only one, and in the 880 there is nothing.
Same thing: All chips work in all players.
Any pinout differences with a/B version ?
I have the datasheet but can not find anything.
Old 15th April 2004, 07:19 AM   #64
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Sigh....do you measure other passives as well IN circuit ?
Rudolf Broertjes
Old 15th April 2004, 08:29 AM   #65
Bernhard's Avatar
Sure ,
A 1541A on board shows something, off board nothing.
Old 15th April 2004, 10:53 AM   #66
Bricolo is offline Bricolo  France
Bricolo's Avatar
In HtP's article about DEM reclocking, he precises that in the non A version, the cap is internal but the pins are connected, so you can certainly add a cap too
Old 15th April 2004, 12:42 PM   #67
rbroer's Avatar
Sure ,
I give up
Seems you don't care about any internal circuit inside the chip, like an emitter coupled multivibrator.
In order to measure the internal DEM capacitor of the TDA1541 you need to disconnect at least one side of it. Since it's located in the TDA1541, you better bring your microscope and tweezers
Rudolf Broertjes
Old 16th April 2004, 05:23 PM   #68
HtP is offline HtP  Netherlands
Originally posted by Pedja
Henk, thanks again for your posts, I consider them very valuable.
I guess it is no problem to have the same delay for all the lines but you will not have the same delay for all the frequencies. Honestly, I do not have an idea if this could be bad or not, just want to note that the general 10ns becomes some 9.7ns on 2.8MHz and 8.6ns on 6.4MHz.
Pedja
Delay itself is not bad. The TDA1541 is an end user of the signals, it takes only some nsec more before the music reaches you. There are no set-up and hold problems in this case.
regards,
Henk ten Pierick
Old 16th April 2004, 05:48 PM   #69
I was not referring to the noise/resistor induced jitter, I was referring to the smoothed waveform like generally less wanted waveform here because of the problem of indeterminacy of the moment of transition in time. Attached are the bandwidth unlimited ~2.82MHz square and squares limited wit RCs of 12ns and 22ns. Are there good reasons why they usually use just square signals here or not? Or the rise time is all we need to determine the best bandwidth of these squares?
Pedja
The digital inputs of the dac form a comparator, they compare the input signal with a reference. Each comparator has an input refered noise density and a comparator noise bandwidth. The total input refered noise power is the input refered noise density integrated over the comparator noise bandwidth. The comparator noise bandwidth depends on how it is build, and how the gain vs frequency roloff is designed.
Total integrated noise power can be calculated into the input refered noise voltage.
A low comparator noise bandwidth gives a low input refered noise voltage. The relation between output slew rate and noise bandwidth is defined by the input gm over C ratio.
The noise voltage converts to time uncertenty, or jitter, with the input signals slew rate.
There are indeed reasons to use square waves, the are fast enough. But if you know the input refered noise voltage, then you can calculate the minimum required input slew rate for a given increase in jitter. If you can do this, than you can also minimize the cross talk of the digital input signals into the dac.
regards,
Henk ten Pierick
Old 16th April 2004, 06:40 PM   #70
Banned
fine, i nearly understood this. Now could anybody please post the schematic of the circuit to get the TTL down to the desired voltages the TDA1541 likes best? And why not with an active element as a differential amp with gain < 1 so the signal would be present inverted and noninverted to feed 2 DACs for balanced operation?
Need info on WS polarity for TDA1541 peufeu Digital Source 4 17th October 2006 04:32 PM
Page generated in 0.11719 seconds (86.19% PHP - 13.81% MySQL) with 11 queries
