mini DSP connection to amp question
I see, I didn't realise you meant using REW from your initial post. Do you mean this?:
Connect an audio output from your computer to your sound system. With most computers, you can use the line out or headphone output with a suitable cable. It is advisable to connect into your system at the preamp inputs, so that the preamp volume control can be used to manage the signal level from the computer.
