What about those cheap DACs ?
Old 9th January 2018, 04:10 PM   #1
loandmot is offline loandmot
Default What about those cheap DACs ?
Hello,
I want to put a small cheap dac in case with one t-amp (Sue AA-AB32313), and have looked up for that.
I use only PCM on PC (not DSD files), and juste want good usb entry (like XMOS), no SPDIF.
I've read good return on Sabaj DA3, but not sure I could use it in my project (the t-amp has 20Kohms entry)
So I've seen those dac, which vould be easy to put in the case and connect to the amp:
XMOS U8 DSD1796
XMOS U8 AK4490
The output seam to be only 1V (some vendors say 2v, but I don't think so), would it be enough ? Could it be increave, with more input voltage ?
And what about to change op-amp or clock? Would that improve the result, or will I just lose money ?
One otherone, which have 2V output:
XMOS U8 AK4490 - 8/9V input
If you don't think those dac or correct, could you advise me some boards arround 100 (a litle bit more is possible) ,
Old 11th January 2018, 03:26 AM   #2
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
No need to spend a huge wadge of cash, one of these will do the job quite nicely. You can buy the kit (which excludes the case) which will suit putting it together with an amp in a case.
I've bought several of these, both with and without cases and they're excellent value - L1387DAC 4X ??TDA1387 ??USB???(??+??),??TDA1543-???
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 11th January 2018, 05:32 PM   #3
Many thanks abraxalito,
I've found it on ebay at 26$, and they say 2V output, so I've buy one.
This being, i've tested 2 FDA amp on USB, one with xmos and the second without, and the sound was much better on the first.
I'm newbees in Diy, so excuse me if I say very stupid:
Do you know if it's possible to change output voltage on a dac..?
I'm afraid 1v won't be enought with the dac i've posted.
And please, excuse my bad english...
Laurent
Old 11th January 2018, 07:40 PM   #4
AudioLapDance is offline AudioLapDance  Canada
XMOS U8 DSD1796
XMOS U8 AK4490
Hey loandmot,
See
Leaf Audio XMOS 384k 32bit DAC: PCM5102, TDA1308, PE-65x12
and
DIYHiFi.org View topic - Leaf Audio XMOS 384k 32bit DAC: PCM5102, TDA1308, PE-65x12
But that's from like almost 5 years ago?!?
Jeff
Old 12th January 2018, 05:13 AM   #5
abraxalito's Avatar
Do you have the link? I did a quick search and didn't see the same one. 2V output for this one isn't going to happen, its got a 5V supply (USB) so cannot swing 5.6V under any conditions (2V means 2VRMS so 5.6V peak to peak).
Its quite possible to amplify the DAC's output voltage yes. That's normally a pre-amp's job. If you meant by 'change' modifying the DAC then usually that isn't possible.
Old 12th January 2018, 07:44 PM   #6
Here is the link: L1397DAC
Yes, of course...Not possible to modifing the DAC...
I just deeded a smal quite good DAC board with USB (only), to put in a small case with the amp, and there are some actually, but for headphone.... I think they don't have enough out power for my project...
So, many thanks for your answers abraxalito.
Old 12th January 2018, 10:51 PM   #7
abraxalito's Avatar
Thanks a lot, seems the search function sucks as I typed in 'TDA1387' and didn't see that one!
If you use one of TI's classD amps they have selectable input sensitivity. Or use TDA8932, this has plenty enough gain to work with the L1387 DAC. But maybe you need still more power....
You're welcome
What about those cheap DACs ?Hide this!Advertise here!
DACS vs Raspberry Dacs hifineo PC Based 22 9th May 2018 04:01 PM
Anyone tried these cheap, Chinese, AK4495 I2S Dacs? Learnincurve Digital Line Level 2 3rd September 2017 03:10 PM
Any good cheap SPDIF DACs? beanbag Digital Line Level 8 20th July 2014 09:40 AM
Cheap DVD players with Wolfson DACs? Rotellian Digital Source 4 29th October 2004 08:23 PM
Audio DACs, Instrumentation DACs. Brian Guralnick Digital Source 10 3rd November 2002 04:56 PM
