Best DAC-chip out there?
Old 3rd January 2018, 07:55 AM   #21
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by canvas View Post
I synchronized 2 DACs on Daphile
A surprising conclusion. But why on earth use Daphile for critical listening?
Old 3rd January 2018, 01:37 PM   #22
canvas is offline canvas  Taiwan
Originally Posted by Joseph K View Post
Dear Canvas!
Very interesting observation.. (and beautiful features on your pcm63 dac..)
I suppose you compared using upsampling (of Daphile)
I imagine that in PCM upsampling mode..
Did you try to run the 4490 dac in DSD mode?
Then you could forget alltogether about comparisons..
I mean a further step up for the modern technology..
My mistake. RTX6001 is based on AK4490. It looks like it doesn't support native DSD playback.
Old 3rd January 2018, 01:43 PM   #23
Any better suggestions? I like it because it's fast and supports wavpack DSD. There is FIFO before DAC anyway.
Old 3rd January 2018, 05:56 PM   #24
vinodt1347 is offline vinodt1347  United Kingdom
Default DAC
I have read good reviews of various Hugo DACs by Chord electronics. They use a proprietary DAC. I haven't actually tried it I couldn't afford it.
Hugo 2 - Chord Electronics Ltd
Old 5th January 2018, 07:30 AM   #25
seanp2k is offline seanp2k  United States
My personal weapon of choice is the RME ADI-2 Pro. The story is that their engineers built it as their in-house measurement and reference platform. It can do balanced headphone output with power to drive planars, has a silly low noise floor, parametric eq and crossfeed options, can be used with or without a computer, etc etc. No volume pot in the signal path either, which was something that was important to me. The manual for it also has technical explanations for many of their design decisions; it’s a good read in and of itself.
Another interesting option are the Soekris ladder DACs. They use FPGAs like the Chord Mojo / Hugo, but operate on different principles.
The Mytek stuff is also in this price range, and the Brooklyn+ just came out a few months back at RMAF. Sabre 9028 Pro-based, IR remote, stepped attenuator (maybe? Unclear), mm/mc phono stage, MQA support if you’re into that.
IMO, once you’re on the level of something like an ESS 9018, anything else out there will only get you minor improvements. This being DIY Audio, I definitely understand the fascination, and it’d be amazing to see some DIY FPGA DACs using Xilinx dev kits or similar. Indeed, it’s been done: DIY DAC goodness
Twisted Pear has their 9038 kit out now, DIYINHK has R2R NOS kits...lots of good stuff out there if you want to build or buy, just IMO the jump from a $300 DAC+Amp to a $2K DAC+Amp is very small while the jump from a iPhone dongle or motherboard stereo out to the $300 system is large.
Spend it on speakers whatever you have now is probably more than sufficient.
Old 5th January 2018, 07:42 AM   #26
analog_sa's Avatar
Sadly, ime the fifo does not cure player/os/usb cable/port dependence. Otherwise it does improve the sound.
If you are happy with Daphile and cannot hear a difference between players because of the fifo, then all is well
Old 6th January 2018, 12:19 PM   #27
Yes, I heard the jitter can still pass to next stage through stray capacitance...etc. (I've no equipment or knowledge to verify this.) However, the FIFO does effectively minimize the jitter. Speaking of the player, each one may sound different, but which is the best? (And what are the criteria?) It appears to me there is still no definite answer for that.
Poting
Old 6th January 2018, 12:48 PM   #28
Joseph K is offline Joseph K  Hungary
For me there is no contest. HQP at best settings direct into 4490 set into DSD direct (driven DSD native, 256)
The rest is playground..
Ciao, George
Old 6th January 2018, 07:18 PM   #29
MarcelvdG is offline MarcelvdG  Netherlands
Originally Posted by seanp2k View Post
This being DIY Audio, I definitely understand the fascination, and itíd be amazing to see some DIY FPGA DACs using Xilinx dev kits or similar. Indeed, itís been done: DIY DAC goodness
There are several people on this forum using FPGA boards for the digital part of their own sigma-delta DACs: Noah Slanter (the one you linked to), xx3stksm (with information spread over several threads, for example Is DSD signed or unsigned? ), blueskull (Ideas wanted -- USB DAC product , but he has a start-up company, so it's not really DIY) and I (see the links in post # 18).
Old 7th January 2018, 12:23 AM   #30
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
Ciao, George
George,
What sort of hardware are you running?
T
Best DAC-chip out there?Hide this!Advertise here!
Chip amp PCB esprit Parts 4 7th September 2017 08:52 AM
FS: CS4397-KS 24-Bit D/A Converter chip + CS8416 192kHz Digital Audio Receiver chip acccruz Swap Meet 0 16th December 2014 08:18 PM
Is there a Class-D amplifier chip that does it's own D/A on chip? gripracer Class D 10 23rd February 2011 05:52 PM
need help with this chip Irwind Kee Chip Amps 6 29th August 2010 04:21 PM
