Need Help!! ES9038Pro DAC + Amanero w/ No Sound Output.. :(
Old 30th December 2017, 06:36 PM   #11
ZoSoNCSU is offline ZoSoNCSU  United States
Send a message via AIM to ZoSoNCSU
Well I am pretty disappointed right now... After testing this DAC as shown in the pictures above (working) for days; I finally had all the hardware needed for the enclosure. So I put the board in using standoffs to keep it above the steel enclosure base. When I finally finished putting the screen and buttons into the face plate and turned the unit back on the screen shows the initial prompt for 1-2 seconds max and then immediately fades to black. I have had some people saying they think it is a dead short, but I have still not found it. Please help!
My Personal HiFi Audio Builds and Reviews (no ads or trackers!) Just HW builds logs, build videos, vintage parts recycling by recertifying them with a Sprague Tel-Ohmike TO-6A, High Res Music, HW Reviews, etc: https://hallmanlabs.com/
Old 30th December 2017, 06:42 PM   #12
Wungun is offline Wungun  Canada
Take it right back out of the case...
Power it back up but be ready to shut it down right away if you don't see the screen come on!
Maybe do the "lightbulb variac" test on supply power....?
Old 30th December 2017, 07:14 PM   #13
Yeah I am currently working backwards to get back to the point where it last worked correctly. Will let you know what happens.
If anyone else has any guesses/insight they can offer please feel free!
Old 30th December 2017, 08:38 PM   #14
So I worked backwards and removed the DAC PCB from the enclosure. I even re-soldered the plug and the on/off switch, but I have the exact same problem I described above..
Now I am slightly worried..
Old 30th December 2017, 08:53 PM   #15
Do you have a multimeter? Start metering it out...
Old 30th December 2017, 09:00 PM   #16
The voltages are correct, that is the first thing I did before bothering to desolder or remove the board.
Old 30th December 2017, 09:02 PM   #17
Good... I assume 6ou mean at the connection points. Try to follow the V thru the board now. DC obviously, after the diodes/capacitors.
Feel the regulators too.... Are they cold? Super hot?
Old 30th December 2017, 10:14 PM   #18
I found the problem. The OLED screen's IR receiver is extruding too far from the screen itself and when I tightened it down to the enclosure's front (steel) plate, that shorted the pins.
EVERYTHING IS WORKING!!! Keep an eye out for my review now that I have no issues I can begin rolling my discrete op-amps up for review! Should be posted in the next week on my site in my signature below.
Old 31st December 2017, 03:32 PM   #19
Awesome! Glad no serious damage was done...
Old 6th May 2018, 04:47 AM   #20
technodude is offline technodude
How does this DAC sound compared to retail stuff like the benchmark or asus?
Need Help!! ES9038Pro DAC + Amanero w/ No Sound Output.. :(Hide this!Advertise here!
A supper dac & headphone amp with ES9038pro op111op Headphone Systems 17 6th March 2018 07:41 PM
DIY ES9038pro Board BJosephs Digital Line Level 26 12th November 2017 08:19 PM
DAC ES9038pro op111op Digital Line Level 3 24th July 2017 12:24 PM
how to mix sound from notebook and external sound card and get headphones output burence73 Headphone Systems 17 29th December 2012 07:58 PM
