Is pin 11 on SAA7210 the same as pin ?? on CS8412?
Old 6th December 2017, 03:04 PM   #1
peetrob is offline peetrob  Netherlands
Default Is pin 11 on SAA7210 the same as pin ?? on CS8412?
Hi everyone,
A problem with a turntable should not give me any problems but working with a DAC dus. A friend of mine has bought a DAC with a TDA1541 dac-chip which I already switched for a S2 (double crown) but I know that such a DAC would sound much nicer (read: more analog) if it was in a Non OverSampled mode. To do so would not be a problem when the dac-chip was partnered with the SAA7220 and the SAA7210! But, unfortunately, this last chip is not there and instead it has a CS8412. To make it NOS, should I connect pin ?? (yeah, which one?) of the CS8412 (instead of pin 11 of SAA7210 (Mute)) to pin 23 of the SAA7220 like I should in a normal Philips cd-player?! Is there anyone who could help me out here?
Thanks in advance!! Peetrob
Old 6th December 2017, 06:52 PM   #2
lcsaszar is offline lcsaszar  Hungary
NOS means you have to remove the SAA7220P/B. Search for ‘Adagio’ TDA1541A non-oversampling DAC as an example.
Is pin 11 on SAA7210 the same as pin ?? on CS8412?Hide this!Advertise here!
SAA7210 instead of SAA7010 Maurizio Digital Line Level 12 21st June 2011 03:48 PM
Do the SAA7210 was much better than the SAA7000 ? gaetan8888 Digital Source 7 13th January 2010 02:40 AM
WTB: Philips SAA7210 decoder hollowman Swap Meet 4 7th July 2009 11:52 PM
Saa7210 Deem.... kevin2059 Digital Source 1 5th July 2004 06:02 PM
Source for SAA7220 and SAA7210 P Howard Digital Source 12 25th May 2004 09:23 PM
