Built a Chinese dac... Distortion and power issues..?
Old 7th December 2017, 02:45 AM   #41
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Was the regulator closest to the edge fastened to the heatsink at some point?
"In the world of commerce and finance it is thought quite remarkable if a man is both clever and honest." -- Demosthenes
Old 7th December 2017, 02:59 AM   #42
phase is offline phase  United States
I have never trusted the components that were supplied with an ebay kit; figured all the functioning parts went to the assembled and tested boards. I have had good luck with starting with an assembled board and swapping most of the parts gradually.
Typically, the supplies on a dac are 9vac for analog on the dac chip, 9vac for digital on dac, maybe receiver chip, and 15-0-15 for the analog output.
Old 7th December 2017, 03:45 AM   #43
Wungun is offline Wungun  Canada
Yes, and the middle one too... I expoxied them to the heatsinks after I soldered the regulator on without the heatsink attached... too low to use the mounting screw.
Old 7th December 2017, 03:46 AM   #44
The supply transformer is 9VAC... So the board must be operating at a lower voltage than that.
Old 7th December 2017, 09:45 PM   #45
You are correct, the chip will often have a requirement for maybe 3.3v or so, but you need to read a data sheet to verify that.
Old 9th December 2017, 09:01 PM   #46
Well, managed to get a partial refund for the DAC... And purchased this one... Assembled!
Maybe not the same quality caps, but now I have spares
Better RCA's, XLR's, and a simpler 9VAC input/rectifier section....
So some easy upgrades possible.
Already ordered a pair of Burr Brown mono OPA134's to compliment the Burson's. The easiest of upgrades!
If I can figure out how to desolder the dip8 Burson's from the other board! Screenshot_20171209-155517.png
Old 9th December 2017, 11:30 PM   #47
I would snip the leads off the board, then snip the adapter into eight parts, then individually remove those from the pins on the op amp module. I would wait and just use the sockets for them with the new board, at least for a long time until you are sure that nothing else will be swapped.
Those modules work pretty good with a 4.7uf 50v, right on the pins, under the board too, along with any smaller, film parts.
That new board looks pretty decent if it comes as shown, I have a similar one that uses an ak4495, I put a snubber circuit on each set of diodes too, smoothed out the sound, more details too.
Old 11th December 2017, 10:19 AM   #48
So, physically cut up the pcb to get at each individual leg?
Built a Chinese dac... Distortion and power issues..?Hide this!Advertise here!
Any Good Chinese Built 3 Way Active crash999 Analog Line Level 4 13th April 2017 09:59 AM
Stability issues with a closed loop class D amp built with TAS5103 asenapati Class D 21 1st March 2017 03:40 PM
First distortion pedal issues supermoose2011 Instruments and Amps 7 22nd March 2011 03:31 PM
anyone built an amplifier Distortion measurement circuit steevo Solid State 16 3rd May 2010 06:46 PM
Distortion issues Snickers-is Class D 30 20th June 2006 04:49 AM
