ES9038Q2M Board
ES9038Q2M Board
Old 5th January 2018, 01:13 PM   #81
Naaling is offline Naaling  Portugal
At the risk of muddying the waters further, can anyone offer an opinion on this board?
Assembled ES9028 I2S input decoders ES9028Q2M mill board DAC balance output | eBay
While it "only" uses the ES9028Q2M chip, is the output set up any better?
Old 5th January 2018, 04:48 PM   #82
terry22 is offline terry22
Originally Posted by zek View Post
In other words, none of the boards has a quality output filter (according to your measurements).
Is it possible to replace it by a better one?
Like replacing the 5532 by a Muses02?
Sorry I'm a newbie about electronics
Old 5th January 2018, 05:17 PM   #83
24century is offline 24century
Send a message via ICQ to 24century ES9038Q2M Board
Agree and I actually like it that way, you can swap your own op_amp for your need, this way to keep board cost down and you create your own style.
Still, can see how the 2nd gen board is going to make much difference vs. previous version, will pass this one but open to hear others experience and suggestions.
BTW, I like the sound of 9038q2m, good on both instruments and vocal, good dynamic with immersive output, setup and circuit design is much easier than AKM product, also with SP-Dif built-in
Old 5th January 2018, 11:39 PM   #84
DPH is offline DPH  United States
That's probably moving in the wrong direction, unless you clearly know you like the sound (if it has one?) of the Muse. Specs are unremarkable.
Happy DIYing, Daniel
Old 6th January 2018, 03:44 AM   #85
It is depends on your experience and op-amp model & type, best operating voltage, therefore no best op-amp, ymmv.
Surprised to see so many people are interested in this small simple board would wide, 2018 is definitely a hi-res year and it shows at the beginning
Old 6th January 2018, 05:04 AM   #86
Surprised to see so many people are interested in this small simple board world-wide, 2018 is definitely a hi-res year and it shows at the beginning
Old 11th January 2018, 12:22 AM   #87
sfb2 is offline sfb2  Germany
It can use Picore but if you connect via I2S you will get native DSD 64/128 not DoP
sorry for the late question but which audio-driver/preferences (ES9028,ES9023 general,RPI-DAC) you use in picoreplayer to make this ES9038Q2M work (and at which max. sample-frequency (over I2S) ?
many thx !!
Old 12th January 2018, 09:42 AM   #88
many thx !!
We're looking for the same answers
Old 14th January 2018, 12:23 AM   #89
madds1 is offline madds1
I usually don’t post but you guys need to try THS4032 Opamp, bypass coupling caps, use slow fir filter (jumper 4) and lastly coax.
This bested my Buffalo with Lundahls (amorphous cores).
For the price. This is a serious contender in almost any class
Old 14th January 2018, 07:37 AM   #90
Green77 is offline Green77  Sweden
If you solder a bridge over the dc blockning caps in the signalpath do you have to desolder the smd resistors also?
BR //Daniel
ES9038Q2M BoardHide this!Advertise here!
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
