ES9038Q2M Board
ES9038Q2M Board
Old 21st November 2017, 08:25 PM   #11
DRONE7 is offline DRONE7  New Zealand
Originally Posted by TioFrancotirador View Post
I am using Volumio with chosen hifiberry digi+ pro as I2S dac in configuration. That's it. It works.
Ok thanks. You are doing i2s>toslink/coax>Es9038q2m
Seems no one has direct i2s pi>Es9038q2m working yet...
It will happen eventually...
Old 21st November 2017, 08:26 PM   #12
TioFrancotirador is offline TioFrancotirador  Poland
No!
I do direct I2S from Hifiberry digi+ pro to es9038q2m (no coax, no toslink).
Toslink is connected to TV and currently playing from TV on the picture (J2 shorted). To play I2S J2 and J3 pins should be open.
Old 21st November 2017, 08:49 PM   #13
Your image won't load so I can't see what you have set but...
The HiFiBerry Digi+ Pro is a high-quality S/PDIF output for the Raspberry Pi. It uses the I2S sound port that connects directly to the CPU without the need for an additional USB conversion.
This is not an i2s output device... it outputs spdif either toslink or coax so you must be sending one of those to the 9038q2m dac...
HiFiBerry Digi+ Pro | HiFiBerry
see attachments...
0=connection x=open...
so coax is J2 optical is J3 and i2s is both J2 and J3
You seem to have it reversed and are using x=connection o=open
If I could see your image I maybe could see if your board is different version.. Mine is VR-1.04
File Type: png Screenshot from 2017-10-11 12-32-24.png (172.2 KB, 227 views)
Old 21st November 2017, 08:53 PM   #14
see attachments...
Right click on image and try to open it in another tab. Should work.
I got same version as you and J2 shorted is for toslink and J3 shorted is for coax in my board. I2S is when J2 and J3 are opened or both shorted (I just tested it).
And BTW Hifiberry digi+ pro has also I2S out. You just need to solder 5 pins on the board.
Old 21st November 2017, 10:06 PM   #15
Ah,I see that now !
Hmm, the hifiberry site talks about patched kernel.
I might try some experiments tonight and see what I can make or break..
Thanks for your input..!
Ok, I think I see something...looking at your image you have the standard 3 wire +Gnd connection and checking the HiFiBerry connections..
DAC+ Pro - connect external I2S DACs – HiFiBerry
Assuming pass through on all but the unused pin2-sample rate then the difference is the bit clock which is output at 32/64*sample rate.
I will try upsampling with sox and see if this will get lock...
Old 21st November 2017, 10:56 PM   #16
Ah,I see that now !
Yes.
I am using newest Volumio build. It was updated with kernel to handle Hifiberry digi+ pro two or three months ago.
Old 22nd November 2017, 05:55 AM   #17
freezebox is offline freezebox  Germany
one question to the analog output. Are there serial DC blocking caps in the signal path for the operation in single voltage mode (+15-0)? If so, can they be removed in case of using +15 - 0 - -15?
And@TrioFrancotirador: Do you feed the digital section with 5V or with 8V?
Old 22nd November 2017, 06:17 AM   #18
I am actually using 5VDC. It is enough.
As for the serial caps in signal path it is very interesting note. I do not know ... yet, but I will try it, measure it and post results in the afternoon
Old 22nd November 2017, 07:05 AM   #19
Ah,I see that now !
DAC+ Pro - connect external I2S DACs HiFiBerry
Yes! It works...! Using Generic-2 I2S (rpi-dac) setting in MoOde Audio and upsampling to 32/96 or better with sox gives lock and playback commences...
Guessing here that the internal processing of ES 90xx dacs is at 32bit and this dac is configured to expect 32 bit or better.
May have something to do with the onboard mcu (and it's implementation of filter options.)
Anyways...it works via i2s at upsampled to 32 bit ( or HiFiberry dac @TioFrancotirador ) or possibly Allo Kali reclocker ?? Anyone got one to try ?
Old 22nd November 2017, 07:47 AM   #20
Blackfear is offline Blackfear
Hi, i will try it with Kali Reclocker, but still waiting for this DAC from Ebay (hope this week i will test it), but i think that it should work, if kali lock it...
Vita
ES9038Q2M BoardHide this!Advertise here!
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
