ES9038Q2M Board
ES9038Q2M Board
Old 15th January 2018, 02:15 AM   #91
Lo_Tse is offline Lo_Tse  Canada
Just found this thread and scanned through all the pages. Has anyone tried to use this board with a USB to IIS card, such as an Xmos U8?
Old 15th January 2018, 05:18 AM   #92
madds1 is offline madds1
Originally Posted by Green77 View Post
If you solder a bridge over the dc blockning caps in the signalpath do you have to desolder the smd resistors also?
BR //Daniel
I just left the resistors untouched. THS4032 can't drive capacitive loads. They tend to oscillate and heat up. Leaving the resistors (think it is 1K || 470 = 320 ohms) adds to the output impedance but helps with driving the cable capacitance.
THS4032 has never worked for me in a preamp or a IV stage but as a DAC voltage buffer - it is perfect.
Old 15th January 2018, 06:49 AM   #93
androa76 is online now androa76  Slovenia
Have you tried any other opamp? What is difference THS vs original NExxxx.?
Old 15th January 2018, 08:49 AM   #94
DRONE7 is offline DRONE7  New Zealand
This thread references a number of different boards.... post a link to the one you are enquiring about for a targeted reply.
I use this xmos u8..
NEW XMOS U8 USB 384K 32B module I2S SPDIF output,support DSD for es9018 DAC | eBay
With this dac..
ES9038 Q2M DAC DSD Decoder Support IIS DSD 384KHz Coaxial Fiber DOP | eBay
Old 15th January 2018, 11:59 AM   #95
Blackfear is offline Blackfear
Hello, i have tried AD823, LME49720,OPA2132, now i stay with LME... for me it seems that it gives sligtly more power out than AD...and it has sligtly smoother sound then AD...waiting for OPA627, generally sound of this DAC is very open, rich and full of detail maybe too much transparent for my assembly, previous combos Rpi3+Kali+Mambo LS or Rpi3+Kali+Allo 2.1 or Rpi3+Kali+ES9028q2m from Audiophonics werent so open and transparent, 9028 was close to 9038, but details, dynamics through whole spectrum is better from 9038q2m also paired with Kali, overall sound from ES9023 to 9028 to 9038 is very detailed, i would like to try any 9028pro or 9038 pro through i2s with KaliReclocker onro Rpis3, but maybe in future, also was thinking on AKM4495 or 4497 but there is reported some problems (pops and clicks distortions) during switching PCM or DSD sample rates (same problem with ES9028q2m but now it is supposedly solved..)
Old 15th January 2018, 12:37 PM   #96
PS: I am running onto DietPi + Moode Beta
Old 15th January 2018, 12:43 PM   #97
terry22 is offline terry22
what driver are you using with moode beta?
rpi-dac?
Old 15th January 2018, 12:50 PM   #98
rpi-dac?
need to look into dietpi settings but when I am home... so please wait
Old 15th January 2018, 02:18 PM   #99
Thanx
Old 15th January 2018, 03:06 PM   #100
Thanx
Hello, in dietpi i had selected no driver = just left rpi-2835 (I left it without change after installation...), but in moode driver selection i choosed audiophonics 9028q2m, so it is strange that Moode takes control over dietpi driver (now I am thinking about it...) ? but it works, also tried to switch in dietpi config onto i-sabre-2km driver then restart and no sound so then i had to go into moode driver and to select audiophoincs 9028q2m, tehn reboot and it works again...strange
ES9038Q2M BoardHide this!Advertise here!
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
