DAC blind test: NO audible difference whatsoever
Old 20th July 2018, 07:37 PM   #1891
00940 is online now 00940  Belgium
00940's Avatar
Simple: I know I'm listening to 24/192. I know it must be superior. I'm feeling good about it. I'm more relaxed listening to it. I thus prefer it.
The ABX effort is nice and indeed proves he can differentiate between various operation points of his gear. It is however unproved that it has any correlation at all with his earlier preferences.
Edit. It also shows that it's real hard to differentiate small differences leading to no obvious artefacts (surprised?) and that one can rationalise something as better when it might in fact be less accurate. The jury is still out on whether this is due to a more pleasing distortion pattern or the need to harmonise our knowledge.
All that is excessive is insignificant. Talleyrand
Old 20th July 2018, 07:40 PM   #1892
mmerrill99 is offline mmerrill99
As I edited my previous post while you were writing this, I'll just repeat what I said in my edit:
am I correct in thinking that you want your cake & eat it too? First, you contend that sighted preference might be difficult; then you contend that sighted preference is because of bias. Do you know that an ABX positive result 'proves' that it is not bias?? I really can't fathom the pretzel like logic that is continually displayed here?
Old 20th July 2018, 07:48 PM   #1893
00940's Avatar
Not when multiple factors are entangled.
Old 20th July 2018, 07:48 PM   #1894
Please detail the "multiple factors"
Let me just reproduce a recent post of yours from another thread "What kind of evidence do you consider as sufficient?" about blind test evidence which you consider sufficient
First of, a claim must be made. It means the testing starts with someone who claims to be able to hear something in sighting listening with a particular system.
If we're speaking "evidence", then the factor under test has to be isolated as much as possible. It has to mean blind testing, keeping the system under test as similar as possible to the one that allowed a claim to be made.
I'm not very strict on how "blindness" is achieved. But if the test has to convice people, then it must involve a fair third party (with no particular interest in the outcome) to control the process.
And finally, the test has to be documented, so it can be reproduced.
It has been made clear that blind testing is stressful but I don't see how to avoid its use. Restricting the test to a very particular claim (allowing for training if needed) and allowing the person taking the test as much familiarity with the test setup as he wants might help.
Old 20th July 2018, 07:56 PM   #1895
00940's Avatar
The main problem is that the formation of the preference is unclear (it probably wasn't made on upsampled files though) and that the test system likely creates a difference (typically higher distortion) that is detected by the ABX but might not be the factor at the origin of the preference (might it be bias or other more valid reasons).
Old 20th July 2018, 08:19 PM   #1896
Please quote the evidence you have for this?
It's the same hardware used for both sighted listening & ABX testing - so your contention is that Foobar ABX is creating distortions that aren't there in sighted listening through the same equipment? Got some evidence?
So, you've built a strawman with "probably", "likely" "might be" & you talk about "multiple factors being entangled"
Old 20th July 2018, 08:24 PM   #1897
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
I have followed this thread from the beginning - While progressing on a digital audio journey of my own.
I started with a 18 year old Arcam CD player with extensive modifications.
I built a Cheap Chinese Ebay DAC kit with as many tweaks as DIYaudio could provide and liked it so much that It gave me the motivation to go further.
I now have a Cyrus CDT digital only CD player, and a Chord 2 Qute DAC.
The Cyrus CD source does not use the normal error correction algorithms used with CD, and the Chord is based on a Field Programmable Gate Array so does not use a normal commercial DAC chip. The DAC also takes the digital output from the TV and a PC.
I'm very happy with the performance of the of the digital sources.
And the acid test? My family don't really give a damn about audio BS but I know that they are happier with the audio environment that they now have - What else matters?
Cheap digital sources are a godsend - they have made a radical difference to audio. They are so good that far more consideration needs to be made to the amplification and speakers.
But I am convinced that differences do exist in digital and they are audible!
Old 20th July 2018, 08:43 PM   #1898
I see you edited while I was posting
I posted this real-world ABX example to show what's involved in ABX testing - it's not the simplistic 'ears only' scenario that is usually portrayed. You argue everything else but this central point
The usual defense for ABX testing before preference testing is to ascertain IF a difference can actually be detected - you now try to turn this on its head by attempting to assign to ABX testing something it was never claimed for it.
As I said the pretzel-like convoluted logic on display is breathtaking
Old 23rd July 2018, 01:57 PM   #1899
Max Headroom is online now Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Originally Posted by Xoc1 View Post
....Cheap digital sources are a godsend - they have made a radical difference to audio. They are so good that far more consideration needs to be made to the amplification and speakers.
Yes, it is quite amazing what digital SQ can be had for very little nowadays.
You bet there are differences in digital....oscillator stability/spectrum is the first thing to address.
Dan.
DAC blind test: NO audible difference whatsoeverHide this!Advertise here!
Will a small cap value difference be audible? jb0194 Multi-Way 2 8th February 2012 05:39 PM
Audible difference between DTS and Dolby? arjscott Everything Else 3 1st February 2007 12:33 PM
Which caps make the most audible difference? TDWesty Solid State 5 31st January 2007 05:49 PM
BrianGT Basic v/s Premium - any audible difference ? percy Chip Amps 1 4th September 2004 03:18 PM
RC Tolerance -- audible difference r_s_dhar Analogue Source 6 11th August 2003 07:47 PM
