DAC blind test: NO audible difference whatsoever
Old 19th February 2018, 11:10 AM   #1591
Jakob2 is offline Jakob2  Germany
Originally Posted by DF96 View Post
It is interesting to note all the reasons put forward as to why we should ignore any result which shows that two devices are not distinguishable:
- its the wrong question
- its the wrong people
- its the wrong day
- its the wrong auxiliary equipment
- the people were untrained/stressed/biased/prejudiced
- the music samples were too long/short/simple/complex
- the statistics don't prove anything
Posts like this make me always wonder as we had already discussed some of these points - sometimes even quite "excessive" with cited scientific evidence theory of statistical significance testing.
My concerns start with the usuage of "not distinguishable" as we simply donīt know about that (in the standard tests usually done).
As explained before, we are analysing the data under the premise that the null hypothesis is true (null hypthesis usually means in our cases "data could have been produced by random guessing") and decide about the compatibility of the _observed_ data with this assumption about the null hypothesis.
We do this decision by applying a statistical test (in our case it is quite often the exact binomial test) and using a predefined decision criterion (i.e. the significance level) and as a result we either refect the null hypothesis or we do not reject the null hypotheses.
In the latter case we do not know about the reasons for the observed data because we havenīt researched it. Therefore we canīt conclude that they were "not distinguishable" , may be the DUTs were distinguishable but something odd happened.
All we do know that we canīt reject the null hypothesis as the probability to get the observed data (and more extreme) was above our predefined decision threshold.
What about the ironically listed other factors (i assume that i understand the posters disbelief in the importance of all that correctly)?
Letīs compare it to a list of posted influecing variables in sighted listening:
- knowledge about brands
- different colors
- other peoples opinion about the DUTs
- expectation about a difference in general
- fear about expressing no difference
- not enough listening experience
and surely there are others as well.
In addition one has to maintain the argument that listeners are unable to compensate the impact of these bias factors in sighted listening tests but are totally shielded against any bias factor if only they take part in a "blind" listening test.
And of course you have to stand by this argument even if scientific knowlegde implies that it is wrong.
Curious then that a test finding of 'distinguishable' is accepted almost without comment, even when the electrical difference combined with psychoacoustics means that the DUT ought (probably) to be indistinguishable.
Who decides if something not commented is accepted?
Mind reading abilities somebody?
Maybe people take anecdotical results as exactly that in hte sense of "might be correct or might be not" even if correct it might be relevant for someone else or might be irrelevant.
I have dipped into this thread again. As things have not actually moved on I will dip out again.
Donīt want to be (too) offensive, but moving on starts with acceptance of long established scientific evidence of the bias effects in controlled listening tests (including the double blind feature).
Old Today, 04:18 AM   #1592
Doppler9000 is offline Doppler9000  Canada
DAC blind test: NO audible difference whatsoeverHide this!Advertise here!
Will a small cap value difference be audible? jb0194 Multi-Way 2 8th February 2012 05:39 PM
Audible difference between DTS and Dolby? arjscott Everything Else 3 1st February 2007 12:33 PM
Which caps make the most audible difference? TDWesty Solid State 5 31st January 2007 05:49 PM
BrianGT Basic v/s Premium - any audible difference ? percy Chip Amps 1 4th September 2004 03:18 PM
RC Tolerance -- audible difference r_s_dhar Analogue Source 6 11th August 2003 07:47 PM
