DAC blind test: NO audible difference whatsoever
Old 14th February 2018, 06:04 AM   #1581
Turbowatch2 is offline Turbowatch2  Germany
Concerning DA C's I have my personal theories. There should be a point where the reproduction leaving the DA's pins is perfect. If this is achieved, any difference between the DAC chips is just a matter of the parts that push the signal in the line output.
The digital input signal has to be perfect, of course. From this side, the “better” DAC would be the one that can reconstruct a digital signal that has some kind of imperfections, to a perfect output signal.
On the other side, there could be coloration's in sound that are leading to a different sounding analog signals, but without being better or worse. Loudspeakers and amps together with wiring always have a coloration, which also depends on the listening room. There are no technicaly perfect audio systems, just as a trumpet or piano does not sound identical in different rooms, but a defective instrument sounds wrong in any room.
So can there be some tolerance to different “DAC sounds”, as long as this is not distortion or another annoying mistake. But where is the border line?
If you are a “if it measures the same, it sounds the same” person, this sure is blasphemy.
In my personal live, living with Hifi for about 50 years, the measuring technician has always been wrong, because his believe in his actual equipment was wrong. He never measured everything that is possible. He only saw what the analyzer, he had at his time, showed him. He could not imagine that there where audible differences he could not measure.
Then, a little later, a new technique was invented and suddenly the audible was measurable. Like simple distortion measurements, which proved to be mostly irrelevant (Matti Otalla/ feedback) or Klippel measuring, showing loudspeakers in a new light.
Is there no way to discuss in a non aggressive way?
Old 14th February 2018, 06:10 AM   #1582
With your psychological approach, I could not agree more. I have to often experienced how easy it is to make a large group agree to the easy, but wrong argument. Just because the truth was to complicated to be understood by any average intelligence. Education has a lot to do with it.
Old 14th February 2018, 08:42 AM   #1583
miklos is offline miklos  Hungary
miklos's Avatar
Originally Posted by Turbowatch2 View Post
OK, you tell that to someone who, right now, owns 3 different separate DAC's
So maybe my ears are not all crazy.
But I might have expected a little more interest for the technical side, instead of endless "who can / cant hear what" handbaging.
miklos
Old 15th February 2018, 12:27 PM   #1584
Jakob2 is offline Jakob2  Germany
We should emphasize again on one of the most important points of propper experimental design, namely to define a research question/hypothesis that the forthcoming experiment should address.
For instance, looking for parameters of the population is something very different from testing if a specific listener is able to perceive a difference between two DUTs.
Unfortunately sensory testing is a surprisingly complex (or maybe not so surprising as we have to deal with humans who are very complex systems) task and for good reasons there exists a plethora of scientific literature about doing this sort of tests in a propper way.
As Mark4 already pointed out again humans are most likely always biased - as said in posts before therefore there most probably never exists a "ears only" test and everybody should refrain from using such misleading terms - and unfortunately this bias is reflected in stating hypothesis as facts.
A difference not spotted by a person in a "blind test" canīt be important for normal everyday listening? Might sound reasonable, but since when is plausiblity a sufficient conditions for acceptance as correct?
A difference canīt be important if people are so easily distracted to not detect it? Sounds reasonable too, but look at the experiments for inattentional blindness and inattentional deafness.
You might dispute the relevance of the difference but obviously participants are quite easily distracted so that they do not detect the "gorilla" (human in gorilla mask for all Deschamps fans )
So please provide evidence for all these assumptions before stating as facts. Demanding evidence from "audiophiles" (whatever the definition for an audiophile migh be) is a valid approach; you shouldnīt demand less from yourself.
@ Mark4,
iīd still strongly dispute the socalled weak auditory memory theory.
The proīs and conīs of very short music excerpts were already discussed in this thread and imo it is obviously dependend on the research question / variables under examination.
If we are looking for practical relevance for normal listening obviously everything that canīt be remembered after a couple of seconds wouldnīt be of relevance because you would not remember.
That working with short samples might be suitable for efficiency reasons or certain research topics is a given.
@ DrDyna,
yeah, fooling audiophile listeners is quite easy - itīs quite easy to fool professional listeners as well, just remember the often told story of the bypass EQ - but as a mere fact that should be seen as a strong warning to not underestimate the difficulties of obtaining _correct_results .
Let me once again point to the "gorilla" in our midst.
Stating that fooling people is easy and than assuming that they will not be fooled if only put in a "blind" test is a contradictio in ratio .
Old 15th February 2018, 02:16 PM   #1585
Markw4 is offline Markw4  United States
Originally Posted by Jakob2 View Post
@ Mark4,
Regarding short auditory memory, I believe there is a range of time, depending. From personal experience in one of PMAs most difficult listening tests, in that case my particular auditory memory was quite short. So I will stick with, "it can be very short, depending."
On the other hand, some types of auditory memory seems to persist for a long time, years in some cases. A audiographic memory of a well known song in the mind of a singer might last decades and may be played back mentally at will.
I think it probably depends on the complexity of memory involved, and the familiarity with the sounds. The exact spoken sound of a word may persist longer if in a language with which one is highly fluent. Otherwise, if gibberish noise, it may fade from memory rather quickly assuming all of the details were ever captured at all.
Regarding relevance, memory duration matters little for musical enjoyment. Musical enjoyment occurs in the moment, and also perhaps as savored from memory. A memory that one had a pleasurable or unpleasurable experience is enough to affect how happy one may be for a more prolonged time. To me, that makes it relevant.
Old 15th February 2018, 03:49 PM   #1586
anthonybisset is offline anthonybisset  Japan
Auditory perception is temporally bound. So is visual perception.
Imagine being shown an image for 1 second (man sitting on a bench at a bus station with a newspaper in hand, several people in frame). Recall what the headline in the newspaper said? Okay, now imagine being shown 4 different images for 1 second each. Can you remember what the headline in image 2 Said? Okay, now imagine you can loop this repetition of images. Can you now easily recall what the newspaper headline says in image2? After several loops?
There are so many studies *proving* this but we don't need to reference them. Our own experience bears this out everyday. More time to focus increases recall of detail.
When we're trying to quantify the quality of a DAC:
- there are listeners who can hear the difference
- there are listeners who cannot
- there are listeners who think they can hear a difference
- there are listeners who think they cannot hear a difference
Everyone's experience is valid but perceptions can be formed regardless of signal reality. So what can we know?
- Some people have amazing pitch correlation
- Some people have amazing transient/phase awareness
- Some people have amazing amplitude acuity
- Some people have great acquisition fidelity across the entire bandwidth
- Some people have narrow acquisition fidelity with increased resolution at particular frequencies.
Does a DAC's performance matter when > 50% of the public can't agree? well, I know a lot of women, (seems few contribute around here), who can hear more details than their male counterparts (including me.) If an improved DAC is just for the women in your life, or your kids, then that is probably a good enough reason to embrace a higher precision offering (if said DAC manufacturer is not a woo-spewing parasite leaching off the music loving community.)
& then there are a lot of cool DIY options, for example the SOEKRIS DAM 1021.
As a friend of mine used to say,
"After a certain number of bits no one cares anymore."
I guess the real question is, how hard does one have to focus or train in order to perceive a difference and does that relate in anyway to subconscious awareness of sound quality vs conscious awareness of sound quality? IOW, do people already perceive quality sound but cannot (ABX) test out as they have no listening skill?
I have no idea nor do I intuit anything here. So for me, pursuing the ability to differentiate sources on the premise that my subconscious is already perceiving those differences is an unnecessary line of questioning. OTOH, I don't think it's a bad thing for audiophiles to do some light ear training as the rewards of being able to listen with more acuity are justification alone.
Learning that we can notice more detail by looping sources, instantly switching between them and adhering to head-in-vice type protocols is valuable to the art of signal reproduction. I can get behind anything that increases our ability to communicate and listen.
Old 15th February 2018, 04:19 PM   #1587
Many good points, thank you.
If I may, I might restate you friend's observation to something more like, "After a certain number of bits, sufficiently accurate in time and amplitude, including enough bits beneath the noise floor, then no one cares about bits anymore."
Old 16th February 2018, 10:09 AM   #1588
At that point i totally agree.
Or see for example the sound of a specific instrument (or instrument class), that can be quite easily transferred to long term storage and remembered for very long time spans.
Afaik which way we parse and store this sort of information is still unkown.
It seems that there exist a direct path somewhere that does not need conscious processing during the transfer.
Of course, maybe i wasnīt precise enough with "weak auditory memory theory" - we know about the (although varying) time spans of echoic memory and working memory - and the consistent part of every memory theory iīm aware of is, that for transferring something to long term storage, categorization takes place (although see above storage of sounds seems to be at least partly sort of a autonomous process) and works often the better the more different parts of our brain are involved.
Which is what i meant; the usual "weak auditory memory theory" works along the line that music samples have to be short because the auditory memory is weak and listeners would not be able to remember after a short time span.
That the quite diverging time spans for the various memory mechanisms (according to the literature) present a counter argument is often neglected in the discussion about test protocols.
But, more important, it ignores that the emotional response might only occur after a longer time span and that listening to short sample tends to favour the analytical approach to the music while preventing to consider appropriately the emotional response.
The enjoyment while listening to music (or more specific the degree of enjoyment while listening) is certainly something that can be remembered too.
So, its a valuable approach to listen to longer music samples to get a feeling for the impact of the presentation while later zeroing in by using short samples to work out what the physical differences really might be.
Old 16th February 2018, 10:31 AM   #1589
Originally Posted by QAMAtt View Post
Sorry, I got very busy over the holidays.
Never mind, as you see iīm not able to follow up in time either...
My issue isn't that Clark and Frindle were lacking enormous details. My issue was that you portrayed them, IMO, as a bit more definitive. And then upon reading the actual papers, there was no meat there.
Which goes back to my original point: The science here is poor (something you didn't really refute).
I canīt refute it, because a lot of data is often missing. Furthermore iīve often encouraged people (who believe in hearing thresholds as hard facts valid for every listener) to read the actual publications to find out what the limits are.
But as said before i was wondering that you seem to dislike accepting Clarkīs or Frindleīs results due to missing a detailed description of the experimental procedure (and therefore being not able to evaluate scientific rigour) but proposing a different approach which would not provide such sort of information either.
Or, did i miss something?
But peer review wouldn't accept a statement such as Clark's without supporting evidence. Clark's statement, when he made it, wasn't widely known and didn't cover the methodology. And it's still suspect today, nor has it be replicated. Thus, how did it get through peer review? Peer review, by design, would reject new and novel statements of fact without supporting data.
We should not expect more from the peer review process than it can deliver.
As there exists (most likely) no perfect experiment there exists (most probably) no perfect documentation either. To a certain degree someone (reviewer, editor or reader) has to trust in the honesty and ability of the experimenters.
Neither Clark nor Frindle claim to have found a good estimator for the mean of the underlying population but presented results that they found during experimentation under certain constraints and a limited number of participants.
Usually we would give them credit in believing that they were able to get their instrumentation right, measure the right things and avoid the basic errors in experimental setup and execution.
Old 17th February 2018, 11:34 AM   #1590
kapelli is offline kapelli  Poland
I listened to about 6 DAC in last year. And, believe me, each of them was clearly audible different. Entry level and high end. However, what's most important, that you have to pay tremendous amount of money for slight improvement. So anything from build in Auralic Aries Mini up to Exogal Comet Plus, Mytek Brooklyn and Arcam D33.
I have not heard ES9038 DAC, and I am thinking of going into cheaper DAC than my Coment, due to various reasons, however, all PCM and ESS solutions I heard were quite open and bright, especially PCM and for example ESS Based DACs have great soundstage without harshness, which I recognize, in Arcam PCM based solutions.
DAC blind test: NO audible difference whatsoeverHide this!Advertise here!
Will a small cap value difference be audible? jb0194 Multi-Way 2 8th February 2012 05:39 PM
Audible difference between DTS and Dolby? arjscott Everything Else 3 1st February 2007 12:33 PM
Which caps make the most audible difference? TDWesty Solid State 5 31st January 2007 05:49 PM
BrianGT Basic v/s Premium - any audible difference ? percy Chip Amps 1 4th September 2004 03:18 PM
RC Tolerance -- audible difference r_s_dhar Analogue Source 6 11th August 2003 07:47 PM
