Removing / replacing output caps on a DAC
Old 11th November 2017, 12:10 AM   #11
ig983 is offline ig983
At the moment the first elements in the amp are two resistors 680ohm and 47K. I took out a cheap 100k pot and placed just two (higher quality) resistors to give me a fixed value and the rest of the volume is contolled digitally.
I hope this answers the input impedance question.
Old 11th November 2017, 12:19 AM   #12
rayma is offline rayma  United States
IF a low end roll off at around 20Hz is ok, then you could make this work, especially if
the coupling capacitor is increased to 0.22uF or more. The R100 and R101 should be increased
to about 200k to minimize the bass roll off. If you could replace the 47k that you installed
in the amp with a higher value of 100k or more, that will also help. The same goes for
increasing R72 and R73 to about 200k. Is it a tube or transistor amplifier?
Old 11th November 2017, 12:30 AM   #13
This is a tube preamp / LM1875 chipamp hybrid.
I can change the 47k to 100k, no problem.
What levels of attenuation would that give me?
Old 11th November 2017, 12:32 AM   #14
I can change the 47k to 100k, What levels of attenuation would that give me?
If you want an input attenuator on the amp, just scale up both input resistors
by the same factor to keep the same attenuation. I'd scale both up by around
a factor of four, from what you have now.
Old 11th November 2017, 12:39 AM   #15
Meaning to keep more or less the attenuation of 680ohm and 47K I`d have to go with 1K3 and 100K.
Got it.
Rayma you`ve been such a help. Thank you so much
And thanks to wwenze and kaputt for their input
Old 11th November 2017, 12:46 AM   #16
The amplifier input attenuation is only about -0.1dB, so the relative values aren't critical here.
I'd just use 1k and 200k.
Old 11th November 2017, 12:51 AM   #17
Ok, I`ll go with that
Thank you
Old 11th November 2017, 10:23 AM   #18
Rayma just one thing, tell me please do you know how the change in uF cap size and higher input impendance should affect the sound? Does it matter?
Old 11th November 2017, 03:36 PM   #19
You can try that right now, before working on the DAC.
Just increase the 47k to 200k in both channels of the amp.
It will improve the bass response. There should be no downside.
The brand and type of capacitor will affect the sound more than
the uF value from changing say 0.1 to 0.22.
Removing / replacing output caps on a DACHide this!Advertise here!
What values are these caps? -- replacing Velodyne SPL II amp caps Jimmy154 Class D 6 9th February 2017 01:50 PM
Question on Replacing Output Caps on Amplifier Wigwam Jones Solid State 12 1st September 2016 09:37 PM
Replacing output caps in Nakamichi CD Player gto127 Digital Source 1 25th June 2015 03:10 PM
Help with removing and replacing rectifier (IRF 6125) from a heatsink board hardhit99 Solid State 14 9th February 2006 09:06 PM
Removing & replacing the X'former of fountek ribbon. Is it...? Lito Multi-Way 0 9th April 2004 05:48 AM
