Chinese AK4497 DAC dual-chip decoder board
Old 30th January 2018, 01:19 PM   #21
dch53 is offline dch53  Australia
I've only tried 44.1kHz so far. I that isn't working there didn't seem much point trying anything higher.
Old 2nd February 2018, 06:00 AM   #22
gentlevoice is offline gentlevoice  Denmark
@dch53: Hi again ... I've read through the thread and also taken a look at your scope photos. And if you have connected the wires correctly (BCK to BCK, etc.) then I would have expected it to work.
However, I notice that in one of the first posts another diya member says that there should be an incompatibility between the Amanero and this DAC board due to a different definition of the I2S. Not knowing what this might be I personally would contact with the seller to find out how the standard he uses differs from normal I2S - what Amanero uses. And also to clarify how this seller's recommended USB card is different from e.g. the Amanero. Could be there's e.g. a timing difference (??) between the different digital signals that may not easily show up on a scope (?) ..
Best of luck in finding a solution ...
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 2nd February 2018, 09:54 AM   #23
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
I just ordered an identical board from AliExpress and will keep you posted as to how it works. But, it may take up to three more weeks before I get it, depending on customs. Could also be 2 months.
All atoms to the right!
Old 3rd February 2018, 12:48 AM   #24
Jesper
Hi Jesper,
Thanks very much for this. Excellent advice. I did message the seller a few days ago but haven't had a response. I'll try again.
I used the link in my original order email and found this:
"7. support DOP- DSD64/128 (Need buy XMOS U8 USB Card)"
I found one here: XU208 XMOS USB card interface U8 upgrade / DAC-in Headphone Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
The pin-out looks like this:
The 3 pins that are labelled (GND, DSD and MCK) are the same as the Amanero board. As you said though, maybe there are signal differences. I'll wait and see if I get a reply from the seller.
Dave.
Old 3rd February 2018, 02:47 AM   #25
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
If you have exhausted all other options you might have to buy the recommended USB board to verify it works with the DAC board.
If it does you cans scope the IP's if it doesn't you can get your money back.
They do state that this DAC is compatible with Amanero using revised pinout.
I was interested in trying this board but I couldn't get a straight answer from any of the vendors WRT DSD256 operation.
Terry
Old 3rd February 2018, 04:05 AM   #26
Terry
Thanks Terry. I didn't see the statement about the Amanero board.
I'm also trying to verify that the information I have on the DAC board USB pin-outs is correct.
Old 3rd February 2018, 05:24 AM   #27
zenelectro's Avatar
Here's a pic of exactly the same board but it's labelled.
Old 3rd February 2018, 05:33 AM   #28
Thanks very much indeed. That's how I currently have the Amanero card connected.
Old 3rd February 2018, 07:35 AM   #29
androa76 is offline androa76  Slovenia
And in the middle is another pin ...take a picture of under board to see where it is connected??
With green board it could be connected but with amanero no because it has not spdif pin, that i think must be connected to middle pin.
Old 3rd February 2018, 10:45 AM   #30
zenelectro's Avatar
Well this is very interesting. On the labelled board I don't think this is a through hole, however this image of non labelled board shows a hole.
Good snooping androa!
Chinese AK4497 DAC dual-chip decoder boardHide this!Advertise here!
Dual Mono DAC AK4490/AK4497 cal1sto Digital Line Level 397 8th May 2018 11:45 AM
Dual AK4497 DAC Project nautibuoy Swap Meet 2 26th June 2017 08:22 AM
Chinese Time! Which decoder is better? HumbleDeer Digital Source 5 24th January 2017 09:38 PM
Does it exist: Dolby Digital Decoder Chip Or Board? 6f6 Parts 7 14th March 2007 11:05 PM
