DIY PCB Clock
DIY PCB Clock
Old 12th September 2017, 09:52 AM   #1
ncclabs is offline ncclabs  Viet Nam
ncclabs's Avatar
Default DIY PCB Clock
PCB Clock that I have perfected.
I use 5V LT1763 (low noise) to supply power to the crystal.
Old 12th September 2017, 09:57 AM   #2
DF96 is offline DF96  England
Now all you have to do is invent a perfect way to connect it to a circuit.
Old 12th September 2017, 10:13 AM   #3
ncclabs's Avatar
I'm thinking about that, can you give me advice
Old 12th September 2017, 01:03 PM   #4
Sorry, no. I know that I don't know enough to do it perfectly, or even competently, as my background is audio and radio rather than digital and mixed-signal.
Old 13th September 2017, 06:38 AM   #5
marce is offline marce  United Kingdom
DIY PCB Clock
Clocks generally are best placed next to the device they provide the clock signal too. Sending a clock signal through those sort of connectors is not going to do the signal integrity of the clock any good... Use a small RF with co-ax cable
AC on board, not the best idea... DC only would be best.
Its basically a crystal with a power supply... Is it going to improve an on board clock?
Old 13th September 2017, 01:01 PM   #6
Yes, it is generally a good idea to keep RF oscillators and PSUs well apart unless you want hum sidebands. You have carefully checked the output spectrum? There is more to low noise (i.e. low jitter) oscillator design than merely feeding a packaged oscillator from a low noise regulator.
DIY PCB ClockHide this!Advertise here!
SAA7220 Slave Clock Mode with 11.2 Mhz TTL Clock lscangus Digital Source 4 9th December 2014 03:50 AM
clock, master/slave no clock? pforeman Digital Source 0 29th January 2011 06:17 PM
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
Audiocom clock vs. LC Audio clock KevinLee Digital Source 22 26th July 2004 01:29 PM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
