OPA1632Ds getting super hot in a PCM1792A DAC I'm building
Old 19th June 2017, 04:50 AM   #11
eranrund is offline eranrund  United States
Send a message via ICQ to eranrund
Thanks for the oscillator recommendations!
I got the Bink test CD and made some measurements. It looks mostly clean, but I did manage to catch something weird on one of the channels. The blue/purple are +/- of one channel, and the cyan/yellow are the +/- of the other channel.
Are these tiny spikes on the yellow channel the mess I am looking for?
Unrelated, but my MCK signal looks terrible anything I can/should do about that?
Old 19th June 2017, 06:40 AM   #12
Shinja is offline Shinja  Japan
In the I/V stages, OPA1632's Vocm pins looks problematic.The Vocm pin set *output* common voltage.+- input pins are virtual-shorted each other, but not to Vocm.PCM1792A output "sources" (↔sink) 6.2mA at digital silence.So OPA1632's +- input pins potential will be 0V+750Ω*6.2mA=4.65V which exceeds PCM1792A's limitation, or even its supply voltage, it must be clamp protected somehow.
I don't know where your waveform probed, but I can't see why, how your DAC runs in such a condition.The solution is to set Vocm pin -4.65V or sink common 6.2mA with CCS.
Old 19th June 2017, 06:45 AM   #13
Dimdim is offline Dimdim  Greece
I don't suppose that by any chance your oscilloscope's probe is set to x1?
http://www.dimdim.gr
Old 19th June 2017, 07:20 AM   #14
Why do you think it exceeds it's limitation? It's analog supply voltage is +5V. Waveforms were probed on the PL connectors - so at the end of the signal chain.
Old 19th June 2017, 07:23 AM   #15
Hm, good call. Pretty sure it was set to x1. I'll try again with x10. Thank you!
Edit: Looks a bit cleaner with x10 but still not a nice square wave
Old 19th June 2017, 11:27 AM   #16
amb is offline amb  United States
amb's Avatar
Don't expect a nice looking square wave if you're measuring tens of MHz with a regular scope's test probe. The ground lead has enough inductance to make the waveform ugly. Read up on RF measurements...
Old 19th June 2017, 12:11 PM   #17
Oh, I remembered the supply is 3.3V.Then it is inside of rail voltage.Although that, I recommend the node voltage to be 0V or so as nominal condition in the datasheet. When the node voltage is 4.65V , internal "current segments" (CCSs and switches) comprised of Pch MOSFETs are running low Vds and may affect switching characteristics - it may be the cause of the glitches in your waveforms.
I found similar discussions in this thread.Current differential to voltage line level from PCM1794 et al
Old 19th June 2017, 05:15 PM   #18
Didn't think 12MHz would be fast enough for that effect... I'll google and read about that. Thanks
Old 19th June 2017, 05:16 PM   #19
I'll take a look at that thread. Thank you!
Old 19th June 2017, 08:56 PM   #20
Shinja - thanks again for pointing out the Vocm issue and the other thread. While I am not sure it contributes anything to the heat issue, it's definitely a problem in the design. I'm wondering where to go from here. I could create a -4.65V reference on Vocm but to my understanding this will result in DC offset I'll need to remove with capacitors. Is that correct?
Would using a CCS be better (and not result in DC offset)?
OPA1632Ds getting super hot in a PCM1792A DAC I'm buildingHide this!Advertise here!
My first DAC on PCM1794A - help needed. Chulia Digital Line Level 29 14th June 2018 09:53 AM
pcm1794a DAC Mute function hug96 Digital Line Level 24 26th May 2015 07:40 AM
Comments on PCM1794A DAC design novec Digital Source 54 4th June 2012 07:58 PM
Micro DIR9001 + PCM1794A DAC theAnonymous1 Digital Source 88 14th June 2010 09:01 AM
FS: Twistedpear PCM1794A DAC Board pftrvlr Swap Meet 2 18th April 2010 03:52 PM
