Improving passive I/V for Pi dac 8 x TDA1387 - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 19th June 2017, 05:34 AM   #11
Thanks. Great info.
I am using Moode on Pi3 with upsampled output from 88k to 192k, so I am wondering maybe the EQ filter is not needed. If I remove the passive filter, can I connect direct from dac I/V to RCA output with a simple filter (eg 10nf to ground)?
Old 19th June 2017, 06:11 AM   #12
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I'll have a look at increasing the damping of the filter - that way you'll get the benefit of the rejection of images at higher frequencies but not have the rising HF response needed for NOS eq. I think its going to be simply tweaking a resistor value....
Attached the revised schematic - I took it that you'd settle on 100R for the I/V resistor and adjusted the other values accordingly. It looks impressively flat now
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 20th June 2017, 04:15 PM   #13
sumotan is online now sumotan  Indonesia
Hi Guys
Is there another way around this ? Years ago I experimented with something similar
base on an article in Amateur Audio by Rubinson. No matter how the filter was tweaked,
it didn't sound good. If I recall correctly that filter was a butterworth network
Cheers
Old 20th June 2017, 11:56 PM   #14
abraxalito's Avatar
'This' means the I/V stage or the filtering stage? Or both?
Improving on passive I/V isn't possible, the next step up is going to active I/V so as to present a lower impedance to the DAC's current source outputs. By 'active' though I don't mean opamps rather a discrete transistor circuit.
Old 21st June 2017, 05:15 AM   #15
Apologies Abrax I was referring to the filter network
Cheers
Old 21st June 2017, 05:16 AM   #16
abraxalito's Avatar
So your question is 'is there another way to implement the filter?' ? Or 'do we really need this filter?' ?
Old 21st June 2017, 05:23 AM   #17
Yes both Abrax. My experience back then was with
a CS4328 & UltraAnalog dac. In the end I found that a direct connection sounded best . Was using a tube stage. Perhaps it was the tube stage that
managed to mask some of the ultrasonics
Old 21st June 2017, 05:35 AM   #18
abraxalito's Avatar
My experience with passive (LC) filters has been they've only helped or had unnoticeable effect, never reduced the SQ with any DAC I've built. But then I've only been using SS output stages and amps, no toobs.
Old 21st June 2017, 05:41 AM   #19
Well can't argue with you on this Abrax
Perhaps it too was my inexperience back
then.
Cheers
Old 21st June 2017, 05:52 AM   #20
abraxalito's Avatar
Well with those two DACs you mentioned you'd not have much drive capability available. Passive (LC) filters tend to be low impedance so need to be driven from low impedance (or alternatively, matched impedance as is the case with passive I/V drive).
TDA1387 continuous calibration dac terranigma Digital Source 130 12th September 2016 11:00 PM
TDA1387 8x DAC Sync Problem SonicFreq Digital Line Level 2 22nd December 2015 04:22 AM
Dirty Dac, 16x TDA1387 dual mono symmetrical. Koifarm Digital Line Level 16 30th August 2015 11:28 AM
build a nos dac with tda1387 Tendy Digital Source 24 13th November 2014 12:33 PM
Copyright 1999-2017 diyAudio
