WM8740 single power supply output buffer
Old 15th June 2017, 08:07 PM   #1
zdr is offline zdr  Belgium
zdr's Avatar
Default WM8740 single power supply output buffer
I am looking for recommendations for single supply (5V) compact output buffer for WM8740 which has differential voltage outputs. I could not find any specs for these signals, but I am guessing they must be between 0 and 5V, which is the power supply of the DAC. I would like to run whole board (USB->Audio Widget->I2S->ADAU1701 DSP->I2S->WM8740 on USB power.
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 16th June 2017, 01:00 AM   #2
didiet78 is online now didiet78  Indonesia
Why not take one output?
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 16th June 2017, 02:19 AM   #3
chris719 is online now chris719  United States
Not for sale yet I think, but the lazy (minimum component) approach for single supply headphone drive.
http://www.akm.com/akm/en/file/datasheet/AK4205EN.pdf
Old 16th June 2017, 07:12 AM   #4
zdr's Avatar
Now that you mentioned it, do I need a buffer at all in that case? WM8740 already has a low pass filter embedded...
Old 16th June 2017, 07:25 AM   #5
Mayday is offline Mayday  Sweden
Project Horder & Blogger
Mayday's Avatar
Just a thought, it isn't possible to use an AD8606 as buffer? It is one already working on a 5Vdc supply on the boards, so that should not be an issue?
There are several other low supply voltage opamps, I don't know how they behave on a single supply though.
I have some, don't remember which though, I'd have to check my parts-drawers and look at the datasheets.
The more you learn, the more you realize how little you know...
My blog, go have a look
Old 16th June 2017, 08:05 AM   #6
If you need 2vrms out, you need diff output.
First, try single ended out with just cap for dc blocking
Didiet
Old 16th June 2017, 08:13 AM   #7
I would not bother with single supply if you're going for "high-end". Look into Jens' SilentSwitcher to get a negative supply from the 5V input. Or build your own using similar ICs if you're up for it.
If you want excellent load drive capabilities I would look at OPA1622.
Old 17th June 2017, 09:37 PM   #8
zdr's Avatar
This one should work on single supply with output cap added:
DAC with WM8740
unless I am missing something.
Old 18th June 2017, 08:11 PM   #9
zdr's Avatar
Not really, Adau1701 dacs already have 0.9vrms and sound great.
Sent from my ZTE A2017G using Tapatalk
WM8740 single power supply output bufferHide this!Advertise here!
Single-supply buffer help marshaul Analog Line Level 27 12th July 2016 01:00 PM
Wm8740, possible discrete filter/buffer? Mayday Digital Line Level 117 24th January 2016 04:21 PM
Single supply buffer for OPAMP stage? bastibasti Solid State 0 22nd October 2015 08:08 AM
pcm1792 output circuit using single power supply? cbriere Digital Source 1 10th April 2008 08:07 PM
Multiple amps + single power supply = unstable output d0s4gw Solid State 2 22nd June 2005 07:07 AM
