Denafrips discrete R2R Multibit
Old 18th June 2017, 05:34 AM   #61
sumotan is offline sumotan  Indonesia
Technically speaking lowering esr & noise might be the way to go
with cap banks but I never found them to sound better then normal
caps approach if properly set up. Think the better way is to pre filter
the AC prior to main caps. Anyway lets leave that for another thread
Cheers
Old 19th June 2017, 08:38 AM   #62
xx3stksm is offline xx3stksm  Japan
xx3stksm's Avatar
Originally Posted by canvas View Post
According to someone, the Denafrips is a 31 seg. 5bit string + 11bit R2R design. However, it has considerable glitches. On low level signal, the glitches could be as high as 10mv.
Here is the measurement about multibit monolithic LTC2642 on my board.
This is -60dBFS signal(0dBFS=2Vrms).Bandwidth is probably 10MHz because of 25MS/sample.You can see 2mV glitch when the signal across 6bits boundary.Maximum glitch of LTC2642 doesn't occur at the point between 0x7fff and 0x8000. It occurs every 6bits boundary.
Glitch is 0.216*2.26,almost 0.2nVsec.This has 20kHz LPF.Datasheet say 0.5nVsec,probably without LPF.
If you decrease the bandwidth as low as 100kHz like this.Glitches will almost fade away.
Another multibit pcm1704 is glitchless as long as I have tested.It is the most surprising thing for me about pcm1704.
I think analog waveform is something subjective.What you can get from somewhat depends on your experience.But audio application is subjective issue, personal like and dislike.So,I like to use analog waveform.
By the way,It's better to use FFT objectively.
Here is the plot of without glitch of LTC2642. If you decrease the magnitude of signal by 2dB ,you can get glitch free condition.Because glich occurs every 6bit boundary.Below -60dbFS with some offset(0x1f) is glitch free area.
This is the FFT of the first picture which has glitch.
The difference between them comes from the difference of magnitude.THD of multibit mainly depends on the magnitude of signal.I think glitch has no influence below 40kHz region,which is already shown from analog waveform.
Old 19th June 2017, 10:10 AM   #63
canvas is offline canvas  Taiwan
Thanks for sharing your findings. The PCM1704 is advertised as 'glitch-free', so that's got to count for something. Did you try adding a ferrite bead after the output? I think they will help for certain degree.
Poting
FS: BUF03,OPA627,AD797,AD844,LT1028... Here
Old 19th June 2017, 11:40 AM   #64
xx3stksm's Avatar
Cheers
I agree with you from my experience.Though I have already retired,I use to run a small electric manufacture for video appliance. Video systems have much frequency range than audio.Noise from power is more critical.
When I had noise related troubles,the final choice was an additional capacitor as close as power pin. 150 microF OScon.This is the end.Another additional caps are not effective. Available space is also limited. One cap is totally adequate enough.
DIYers have time,space and money for their achievement.I think there is difference in degrees of enthusiasm.Mine is not so hot from my history.But I love to see them.
Old 19th June 2017, 11:51 AM   #65
xx3stksm's Avatar
Poting
I don't have experience of adding ferrite bead. There are many characteristic beads.Some have impact on audio frequency range.Of cource,you can select suitable one for your application.
USB powered DAC sometimrs need ferrite.But as long as you carefully design the circuit,you usually don't need ferrite IMHO.
Old 19th June 2017, 11:59 AM   #66
Hi xx3
Meddle with some beads before results aren't
favorable for me. Yes it may sound quieter but
in terms of SQ it adds a constrain dark sound
which makes the music sound lifeless. As for your
comment of bypass at the pin, I prefer to use a 0.47 uf value instead but no oscons on analog
related location
Cheers
Old 20th June 2017, 03:02 PM   #67
Well, I only place the beads after the I-out of a DAC. For voltage signal, I agree that it may not be a good idea.
R2R DAC has been researched decades ago. The engineers of AD & BB put a lot of effort into its design. It's not easy to beat their product unless we also know how to overcome these problems.
Old 21st June 2017, 06:11 AM   #68
Yes Canvas I agree. I use to think that the Ultra Analog dac was the best of the breed but after fiddling with Nos Tda 1541dac especially with
Pedja's AYA ll DS my thoughts have change somewhat. Seems like today's R2R even in discrete
form is missing something. Makes me think that
the Guru's of yesteryear knew things that the new
generation of designers don't or have overlooked
Cheers
Old 21st June 2017, 06:21 AM   #69
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I agree too canvas, the present-day implementers of R2R aren't as experienced DAC designers as those multibit engineers at Philips or BB or ADI.
When the designer of TotalDac was active on DIYA I asked him what the advantage was in going to a discrete R2R. I don't recall him giving me an answer. As far as I can see the advantage primarily is in marketing (discrete carries more kudos than IC) and also in not using no-longer-in-production chips.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 21st June 2017, 06:52 AM   #70
If I may Im gonna go off track a little. Lets forget high res
for a moment & just look at Red Book playback.
I dare say that a properly set up Cs 4328 dac will kill
any chips that being produce now. This lovely dac has
long been forgotten due to marketing hype.
For R2R TDA 1541 is really hard to beat
Cheers
Denafrips discrete R2R MultibitHide this!Advertise here!
Discrete JFET "passive" R2R attenuator easphyx Solid State 3 23rd February 2017 12:05 PM
New Halo Spring Dac R2R Discrete and can do native DSD easy on the pocket too. georgehifi Digital Source 8 13th October 2016 07:21 AM
Schitt offers upgrade from Delta Sigma back to R2R ladder multibit!!! georgehifi Digital Source 4 10th October 2015 02:08 AM
Multibit dac chips - R2R resistors. C6H5COONa Parts 2 12th February 2015 03:22 PM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 10:05 PM
Copyright ©1999-2017 diyAudio
