ClearPath: another ESS DAC project - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th May 2017, 09:28 AM   #21
isiora is offline isiora  Italy
Originally Posted by Idiosyncrasy View Post
Wouldn't that take quite a bit more space though? Very impressed with this project btw!
Of course. In case I decide to replace them, I must review the layout.
Isidoro
Old 2nd June 2017, 08:58 PM   #22
Default DoP and DoPE decoding
I added DoP and DoPE decoder into FPGA. Now the DAC is capable to play DSD64 and DSD128 from USB and DLNA interfaces. The decoding process is done directly into FPGA. That it is independent from the DAC chip and it works with both the ES9018 and the ES9038.
Old 13th June 2017, 07:28 AM   #23
bsy020 is offline bsy020  Israel
So you decode the DSD input to PCM in the FPGA and then feed this to the ESS 9018?
But the ESS9018 converts DSD to PCM, isn't it better to let the ESS9018 do this conversion?
Old 15th June 2017, 01:14 PM   #24
Hi bsy020,
I decode the DoP encoded stream, and under no circumstances I touch the original DSD stream. DoP is an industry open standard and letterally it means DSD over PCM. It allows you to play pure DSD files (.dff, .dsf) on a compliant DoP DAC via a PCM stream. This stream is no longer a stream that contains PCM samples, but is a stream that contains the original, and untouched, DSD bitstream, plus other data useful to recognize it as a DoP stream. Obviousely in order to play DSD files in this way, you need a player or a media server capable to encode the dsd file in a DoP stream.
So, all I do is to recognize and decode the DoP stream into the original DSD bitstream and route it to the DAC chip capable to play DSD.
As you know, all the ES90xx DAC chips are capable to play DSD stream (although they are not pure DSD dac, so they need an internal conversion from DSD to PCM).
For more information on DoP, see http://dsd-guide.com/sites/default/f...andard_1v1.pdf
Kind regards,
Isidoro
Old 19th June 2017, 10:57 AM   #25
Thanks Isiora for clarifying this point.
Great project.
HQ Reference DAC a.k.a. DAC-END R(ESS 9018) v.2 with Lundahl LL1684 output stage mainaman Swap Meet 5 28th April 2016 06:35 AM
ESS-Focal 2 Way (Project Definition) Baronski of Boise Multi-Way 9 2nd March 2016 12:19 AM
ESS ES9023 DAC rvrazvan Digital Source 18 3rd August 2011 06:58 PM
ESS Sabre Reference DAC VS Prism sound ADA-8XR, DAD AX24 and weiss DAC? mbl Digital Line Level 12 19th October 2009 09:48 AM
ESS speaker rebuild project Bndkoss Multi-Way 4 22nd February 2009 04:07 PM
Copyright 1999-2017 diyAudio
