6x TDA543 DAC USB Parallel Fever audio decoder - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th April 2017, 02:23 PM   #1
hollowman's Avatar
Default 6x TDA543 DAC USB Parallel Fever audio decoder
It's $19 USD (+ about $2 s/h) from AliExpress.
It's running a fever (hot!!) so I guess that's what the heat-sink is for.
Not much detail in the description.
Anyone guess what the decoder chip may be?
BTW: Aliexpress also has 4X TDA1543 version (about 60 cents cheaper)...
Again, curious about the decoder IC.
Anyone care to guess?
Thx!
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 29th April 2017, 02:45 PM   #2
QSerraTico_Tico's Avatar
Ask them!
Unfortunately these Chinese sellers often do not know a thing about what they sell. Forget about schematic.
Old 30th April 2017, 10:45 PM   #3
guytou is offline guytou  France
Hi Hollowman ,
I have that card , I found it sounds rather good . The USB decoder chip is marked : CM108 MMSM8 UY01PC-CS 1606 , I couldn't find any datasheet .
"celui qui est parti de rien pour arriver pas grand chose ,n'a de merci dire personne "-Pierre Dac
Old 30th April 2017, 10:53 PM   #4
Bigun is offline Bigun  Canada
Bigun's Avatar
Interesting. Did you compare with any other DACs ? perhaps you had a chance to compare with a CD player or something ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 30th April 2017, 10:58 PM   #5
Hi Bigun , is your question adressed to me ?
Old 30th April 2017, 11:26 PM   #6
NPower is offline NPower  Portugal
NPower's Avatar
I believe is this one (CM 108).
Performance is a state of mind !!
Old 30th April 2017, 11:33 PM   #7
Thank's Npower , it is this one .
Old 1st May 2017, 05:54 AM   #8
hollowman's Avatar
Wow -- the date on that datasheet for the CM 108 is Feb 2007. And those TDA1543s are from the early 1990s.
With the USB controller, there may be ways to tweak its performance by hacking the firmware. Supposedly, that's what Gordon Rankin did with his Streamlength firmware for the ancient TAS1020B (USB decoder chip).
Nice to hear the Fever DAC sounds good.
Old 1st May 2017, 10:16 AM   #9
Hi , I read that interview of Gordon : Q&A With Wavelength Audio's Gordon Rankin | AudioStream .
Great guy . I don't have the knowledge to do the tenth what he did .
The CM108 is isochronous , is it ?
I found that little card with 6x1543 sounds very close to a DAC AH well tweaked . I have also a stock Soekris that I don't like , a 1x1543 , a 4x1543 , a 16x1543.... I like 1543 .
Old 2nd May 2017, 12:39 AM   #10
hollowman's Avatar
Default USB, etc.
I'm not sure how great or awesome Streamlength (asynchronous mode USB) really is?? Rankin found a hack for the TAS1020B -- one that was not so easy to pull off.
That was 8-10 years ago.
Since then, other manuf. have used the same TAS1020B chip with their own firmware.
And some have used Tenor or Savitech decoders with adaptive mode isosynchronous. [Also see this XMOS page for their opinion]
Indeed, about 1 1/2 years ago, JarekC and I discussed this issue at some length in this thread.
Probably. Most of the "older" USB decoders were isoch. by default (like the default/unhacked TAS1020).
Not sure about newer USB decoders (XMOS, Savitech, Tenor, etc.)?? Can they (finally) be easily reconfigured by the end use for synch/asynch., etc.
Interesting that you prefer the 1543 over Soekris.
In any case, if you've hung out here at DIYA for over 10 years, you may recall that the 1543 has sort of a cult following. The 1543 was meant to be an 'Economy' DAC. But DIYers found that certain implementations yield promising results. perhaps the most famous is the parallel NOS DDDAC by Doede Douma:
Description of the DDDAC1543 project
The 1543 also made it into H-Fi Man's 602 portable DAP.
SA9023+ES9023 USB decoder 24bit/96KHz USB DAC WLX nigelwright7557 Digital Line Level 5 14th December 2016 01:07 AM
Drivers for Weiliang XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K goodguy2007 Digital Source 1 5th June 2016 06:05 AM
XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K 32Bit Weiliang Bgt Digital Source 15 22nd February 2016 06:15 PM
Driver for 24bit192K AK4399 + SA9227 + NE5534 DAC USB decoder board Migo Digital Line Level 4 18th January 2016 04:57 PM
Favorite USB to audio decoder? speaker Digital Source 27 4th February 2006 01:47 AM
Copyright 1999-2017 diyAudio
