BluWave USB-to-SPDIF bridge, "a miniature beauty"
Old 12th October 2017, 06:40 PM   #161
EBA is offline EBA  France
Hello Lorien,
For French MELAUDIA FORUM, Jean Louis P of LUXEMBOURG boat 10 Bluwave board.
I am one of this group.
I have a problem with my board.
The board no started and Windows error 10 indicated by my PC.
It is possible to help me.
Thank's.
Best regard
Eric B
Old 12th October 2017, 07:58 PM   #162
Lorien is offline Lorien
Hello Eric,
consulting my notes, it's about a batch of 8 boards and not 10 and the boards you bought are WaveIOs and NOT BluWaves so I might add that you're on the wrong thread!
Anyway, I'll PM you with latest Windows driver for your WaveIO (v4.11) and see how your board is reacting to it!
In addition, let's talk over PMs to get more details from you.
This thread is for another board so let's keep it clean, if possible.
Thank you,
L
EDIT: WaveIO's thread is here, please use the link to report back your results!
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 12th October 2017, 08:15 PM   #163
TirNaOg is offline TirNaOg
Default Blue wave Working with Linux
Hi Lucian
My bluewave arrived and it is a gorgeous looking pcb, even better I've got it working right away with my Linux based server, fed by an Iso Regen and powered by 5v LT3045 reg externally. Out of the box it sounds really beautiful, rich and smooth with deep soundstage. More later... with some burn in and connected properly
Very happy
Patrick
Old 14th October 2017, 11:02 AM   #164
Patrick, thank you very much for your feedback!
I'm glad you like the board despite the long wait...
Old 14th October 2017, 11:08 AM   #165
You are welcome Lucian !
I had another session listening late into the night, the sound with the Bluewave now playing for a few days is spectacular to me. Voices have incredibly realistic nuances and inflections. Soundstage is deeper and wider, leaving the speakers and floating, details are multiplied, with increased air and transparency. Very pure sounding and sweeter... the realism is uncanny.
Old 14th October 2017, 02:07 PM   #166
carsten.witt is offline carsten.witt  Germany
carsten.witt's Avatar
Hi all,
please see NDK NZ2520SDA oscillators group buy
Regards ........Carsten
Old 15th October 2017, 11:53 AM   #167
kimschips is offline kimschips  Denmark
Originally Posted by kimschips View Post
I am using revision 1.1 of my Bluwave board.
Hi Lorien
Have you tested if it make any difference in jitter measured between using a USB2.0 or USB3.0 port?
Old 15th October 2017, 01:02 PM   #168
jameshillj is offline jameshillj  Australia
Hi Lorien,
I finally had the Blue Wave pcb installed in my LM-502 Line Magnetic dac and it replaced the unsatisfactory factory fitted unit - it worked straight away - the tech guy was really pleasantly surprised with how well it sounded, not an easy thing to do.
The initial trial here at home was feeding signal via the SOtM sms-200 server (using the Squeezelite program and data off the HDD) and it seems to be functioning perfectly - the LM-502 uses the ESS 9016 chip and it'll accept up to 24b/192k
However, changing to using the music data stored in the Laptop/jRiver and sending it to the sms-200 via the MPD/DNLA program did present some problems but this maybe because of an incorrect setup of the jRiver program after the computer was upgraded to Win 10 and everything needed attention, including the jRiver program.
The music can be fine for one song but the next new song from a different cd will breakup and static a lot - as a computer 'nonce' this is something I'll have to ask about and get an expert to set it up properly, I think.
Lastly, Plugging the laptop computer directly into the BlueWave pcb, and after some stuffing about, it plays perfectly, but only on 'standard' material 16b/44k but it works!! That's a bit of a Victory to this computer challenged person!
This dac hasn't sounded anywhere as good with either AES/EBU, SPdif or Toslink - it has an optional valve buffer on the output that really changes the sound - makes it 'more musical', if you'll pardon the 'jargon'
Again, Thank You for the device
Old 15th October 2017, 06:15 PM   #169
Originally Posted by carsten.witt View Post
Thanks for the pics Carsten.wit. Great quality soldering!
I wonder how complicated it is to replace clocks like these with mini BNC connectors for external clock input? Anyone know?
Thanks.
Old 16th October 2017, 08:26 AM   #170
@ Kim: well, as you already know, I'm now focused on adding stability of this design when used with all platforms / OSes so measurements had to be done later.
As for jitter on USB3.0 vs USB2.0: the measurement is too subjective in my opinion! Why? Because each motherboard is designed in its own way, with own voltage regulators, PCB layout and parts. Taking them all together, one MoBos might be less noisy than others with better layout than others. I don't own such expensive jitter measurement tools and even if I did, I can only measure the USB ports I have at disposal. This is not objective but a subjective measurement which is mostly good only got me.
At theoretical level (not tested by me so far) the less noise on the USB path (including power and GND reference) => the better. Perhaps this was the reason why GigaByte (and maybe other MoBo manufacturers) decided to implement dedicated USB ports for DACs which - if I recall correctly - are in yellow color at the I/O panel.
Perhaps in the future I'll seek a way to measure "things" and post the result in different configurations. This way you may build up an idea on how USB 2.0 or USB 3.0 will influence the sound.
BluWave USB-to-SPDIF bridge, "a miniature beauty"Hide this!Advertise here!
SPDIF/AES to USB or Firewire "unit"? gentlevoice Digital Line Level 4 21st June 2012 09:46 AM
Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? edbk PC Based 0 1st May 2012 03:40 PM
See my pure "USB 2 SPDIF" ary Digital Source 10 5th July 2007 09:00 AM
Alps RK40 pot aka "black beauty" specs? h_a Parts 2 28th January 2007 08:48 AM
