Najda - problems with popping noise - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th February 2017, 03:16 PM   #1
Default Najda - problems with popping noise
To keep the dedicated thread clean, I have put this up as a separate thread.
Some years ago, I reported my problem about noise from Najda. Even if there
is no signal into Najda (I use it with a HTPC, so for example when I just use
the computer without producing audio) there is a loud pop coming from the
speakers every now and then.
The noise can be described as a loud static discharge. It can be up to 15
minutes between pops, but they can come more often.
If I set the Najda to mute, they are gone. But as stated above, even without
input signal, the noise is present.
We are two users here in Sweden so far that has experienced the problem.
I have seen other posts about the issue in the big thread as well.
All hints or suggestions are welcome!
/Bo
Old 7th February 2017, 11:04 AM   #2
Is this popping audible from all analog outputs at the same time?
Old 7th February 2017, 02:31 PM   #3
Difficult to say, I'll have to pay more attention when it happens.
My hunch is that it can come from either left or right or both. :-)
I have had these pops in both a "normal" setup as well as my current setup with active 2-way speakers + subs.
Objective 2 Amp Popping Noise jschristian44 Headphone Systems 3 12th February 2012 11:54 AM
Popping noise from sub?Could it be the amp? tcsounds3hp18 Car Audio 0 2nd June 2011 05:34 AM
Popping Noise = Clipping ? liggs17 Tubes / Valves 5 28th November 2006 08:16 PM
NAD 2400 popping noise Sarge Solid State 3 8th May 2006 01:38 PM
Question about popping Noise Derrick Tubes / Valves 5 27th February 2004 11:34 PM
Copyright 1999-2017 diyAudio
