AK4458 multichannel DAC with I2S input
Old 31st January 2017, 08:50 AM   #1
zarandok is offline zarandok  Austria
Default AK4458 multichannel DAC with I2S input
Hi all,
I have made this topic for my upcoming project, AK4458 multichannel DAC. There are not too much multichannel DACs on the market, but I need it to drive my active loudspeaker system correctly.
This chip is reasonably priced and has a simple layout (only 48pin) but still have good enough parameters to build an outstanding DAC I think....
I you have any advice, experience, please share it! Thanks...!
/ alternative could be the ES9016 but ESS does NOT support public designs and the costs of a chip incl. taxes and shipping is horrible! /
Old 31st January 2017, 09:14 AM   #2
There are not a lot of designs with this IC yet, but for example OPPO, Marantz and ONKYO...
File Type: jpg carte-analogique-8-canaux-sur-alimentation-principale.jpg (409.0 KB, 797 views)
Old 31st January 2017, 09:17 AM   #3
friskyPL is offline friskyPL  Poland
friskyPL's Avatar
I use miniSharc with miniDAC-8 based on AK4440. Having compared it to DIY ES9018 or AK4495 I am sure that AK4440 is a well sounding chip and you cannot go wrong with the better AK4485. Good luck on the project and I hope to have the opportunity to replace miniDAC with your board ;-)
Old 31st January 2017, 10:13 AM   #4
The first question: should I supply the AVDD and Vref pins from the same regulator like the datasheet recommends? Does it make sense the use of shunt regulator(s)?
"Power lines of AVDD and VREFH1-4 should be distributed separately from LDO and etc. while keeping low impedance. If it is not possible, it is recommended to connect a LPF composed by a 10Ω resistor and a 220uF capacitor between VREFL1-4 and VREFH1-4. ... The VREFH1/2/3/4 pin is normally connected to AVDD, and the VREFL1/2/3/4 pin is normally connected to AVSS."
Old 31st January 2017, 10:21 AM   #5
My secound question: does it make sense to build in a quality oscillator near the IC for the master clock (like by the ESS DACs). Does it improve anything or I should use rather the SCK (or MCK) coming from the receiver?
Old 31st January 2017, 10:29 AM   #6
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Based on my experience with Wolfson DACs I'd suggest if you're looking for the best subjective sound quality, arrange for the loading of the audio output pins to be as light as possible. To do this increase the working impedance of the suggested output circuit in fig75. Scaling all the resistor values up by a constant factor and the capacitor values down by the same factor will achieve this. I'd also suggest reducing the corner frequency of this circuit as 99kHz is rather high for a -3dB point.
For the supply rails, you'll want the lowest impedance to get the best performance. Most standard 3pin regulators don't give particularly low output impedance at lowish currents (of the order a few tens of mA). Shunts tend to do much better - transistor assisted shunts better still. Check the TL431 datasheet for a suggested circuit for a transistor assisted shunt.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 31st January 2017, 10:56 AM   #7
Thanks. I'll try my own shunts first...
Output filter is another theme, I'll use full balanced output, possibly with OPA1632 IC-s (but it is just an idea).
Old 31st January 2017, 11:04 AM   #8
abraxalito's Avatar
On the question about Vref, definitely I'd use a separate dedicated regulator for that, preferably with a passive (LC) filter on its output to get the lowest possible noise.
Old 1st February 2017, 06:00 PM   #9
Hsmeets is offline Hsmeets  Netherlands
You have seen that this DAC is in a QFN package and you have tools and/or skills to solder this leadless package?
Old 2nd February 2017, 07:25 AM   #10
Yes I have seen... I'l try simple with a pointed soldering iron and soldering paste. Bad idea?
AK4458 multichannel DAC with I2S inputHide this!Advertise here!
ES9016 multichannel DAC with I2S input zarandok Digital Line Level 45 31st January 2017 08:52 AM
Which DAC chip with I2S input? Giordano Digital Line Level 6 29th November 2015 07:26 PM
I2S input on Satch dac? ozcal Digital Line Level 2 16th March 2015 08:18 PM
multichannel dac via i2s wischem Digital Source 2 10th June 2014 10:50 AM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 06:46 PM
Copyright ©1999-2017 diyAudio
