AK4458 multichannel DAC with I2S input
Old 10th April 2018, 10:27 AM   #131
Dimdim is online now Dimdim  Greece
I haven't read the AK4458's datasheet in detail, but from a quick scan it looks like you'd need to start by using the PDN pin to do a reset on power-on and then use the I2C pins to connect to the Arduino. Beware that the I2C pins are expecting 3.3V levels, not 5V. So it would be a good idea to use either a 3.3V Arduino or voltage conversion devices.
Of course I'm assuming that you have set the chip up for I2C control.
http://www.dimdim.gr
Old 10th April 2018, 01:58 PM   #132
zarandok is offline zarandok  Austria
Thanks!
I bought a TX0108 isolator module, will try with it..
Old 15th April 2018, 06:07 PM   #133
Testing and first listening impressions...
I'm waiting for some filter caps yet.
(the "old" setup is only for testing!)
Old 19th April 2018, 08:07 AM   #134
Project preview: pre PSU for the DAC, with the same 10x10cm panel size, and 4 galvanic separated parts for DAC digital / analog, OPA + / -.
Reg ICs: TPS7A4501 or LT1963 or optional 3pin...
Old 21st April 2018, 06:04 AM   #135
Some listening with my LXmini system:
The sound seems to be a little raw and not so sophisicated, airy like my older PCM1794.
Ground noise level any dynamics are very good.
Perhaps the capacitors needs time to burning in, and/or I should try other digital filter setups (if I make the controller ready for use).
Old 21st April 2018, 01:20 PM   #136
altor is offline altor  Israel
PCM1794 is better to compare with AK4490/93/95/97 and not with AK4458.
But in any case, AK4458 sound is rather good for 8ch chip.
Much better then AK4440 (I have both).
Regards, Alex
www.altor.co
Old 21st April 2018, 02:34 PM   #137
So, you mean that you do not have an AK4458 vs PCM1794 experience, but the PCM1794 seems to be better than the stereo AK chips...?
You have a nice hompage with intresting projects!
Can I ask how do you make the DAC analog power supply?
Old 21st April 2018, 02:46 PM   #138
No, because last time I made DAC with PCM/DSD-1792/94 more then 10 years ago, and do not have any one now.
It depend which chips.
I think PCM1794 is comparable with AK449x (and AK is better to my mind).
But AK4458 is more simple then AK449x also then PCM1794.
You have a nice homepage with interesting projects!
Thanks.
In AK4458 DAC I used LP2985 for AK and lm317/333 for OP in LPF.
Regards, Alex
www.altor.co
Old 22nd April 2018, 06:38 AM   #139
Can I ask why exactly the LP2985? There are some types with much lower noise and small enough package (e.g. LT3042)...
Old 22nd April 2018, 07:41 AM   #140
Just because of a cost reduction of budget version.
LT3042/TPS7A4700/etc. I usually use in more expansive products.
Regards, Alex
www.altor.co
AK4458 multichannel DAC with I2S inputHide this!Advertise here!
ES9016 multichannel DAC with I2S input zarandok Digital Line Level 45 31st January 2017 07:52 AM
Which DAC chip with I2S input? Giordano Digital Line Level 6 29th November 2015 06:26 PM
I2S input on Satch dac? ozcal Digital Line Level 2 16th March 2015 07:18 PM
multichannel dac via i2s wischem Digital Source 2 10th June 2014 09:50 AM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 05:46 PM
