AK4458 multichannel DAC with I2S input AK4458 multichannel DAC with I2S input - Page 10 - diyAudio
Old 17th July 2017, 11:55 AM   #91
zarandok is offline zarandok  Germany
Hm... The datasheet of LT3042 writes: 0,8uVrms 10Hz-100kHz and 2nV/SqrtHz@10k spot noise. What is a spot noise at all??
But I think noise is just one factor, transient behavior is just as well important.
So do you have better listening impressions with LT3042?
Old 17th July 2017, 12:49 PM   #92
Dimdim is offline Dimdim  Greece
I mentioned spot noise just because the Tent Labs shunt specifies it for their regulator.. It's just a way of "expressing" noise corresponding to a specified bandwidth.
Sure, all characteristics of the power supply matter, including output impedance in this case and PSRR.
Indeed, I have done listening tests with the LT3042 vs. the Trident units in my Buffalo and the LT was clearly better. More resolution, more natural sound, darker background.
But I have not done any comparative testing on AKM DACs (yet).
http://www.dimdim.gr
Old 18th July 2017, 01:12 PM   #93
Thanks Dimdim!
I think I'll design a small LT3042 panel, size und pin compatible with my shunts. This IC costs only about 5€. And then I can easy compare myself which is better...
(I will let manufacture with the DAC pcb-s together)
Do you have maybe a free design for that? Or are there some specialities?
Old 18th July 2017, 01:27 PM   #94
There's not really much to it. I'm attaching my Trident replacement design.
Old 18th July 2017, 08:08 PM   #95
Thanks!
I have imported it to DipTrace, and so there are no copper pours. But not a big deal, it's a very simple pcb...
(but this tiny MSOP package.... I don`t know, is it possible to solder it at home?)
Old 18th July 2017, 08:42 PM   #96
I've soldered a bunch of them, all at home.
But you will need some magnification..
Old 19th July 2017, 11:12 AM   #97
Ok, I'll try it. But before I must complete my shunts...
Old 20th July 2017, 06:18 AM   #98
Some simulations made with TINA. What I don't understand: the output resonances about 100-200kHz (depending from the output capacitor size).
AK4458 multichannel DAC with I2S inputHide this!Advertise here!
ES9016 multichannel DAC with I2S input zarandok Digital Line Level 45 31st January 2017 07:52 AM
Which DAC chip with I2S input? Giordano Digital Line Level 6 29th November 2015 06:26 PM
I2S input on Satch dac? ozcal Digital Line Level 2 16th March 2015 07:18 PM
multichannel dac via i2s wischem Digital Source 2 10th June 2014 09:50 AM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 05:46 PM
Copyright ©1999-2017 diyAudio
