CS8421 ASRC configuration?
Old 23rd January 2017, 05:12 PM   #1
ericj is offline ericj  United States
ericj's Avatar
Default CS8421 ASRC configuration?
I just have a basic question about configuring the CS8421 ASRC chip.
A while back i bought one of these modules:
CS8421 I2S sample rate conversion module upscaling | eBay
As described by the vendor, it is preconfigured for 24/211 output. Trick is, I want to use it with a CS4397 which I'm pretty sure maxes out at 192k.
Having a bit of a brain cramp reading the datasheet. Do i need a different clock to select 192khz?
Old 25th January 2017, 05:03 PM   #2
ericj's Avatar
Anyone?
Though, with careful reading of the datasheet, it looks like the 4397 doesn't accept i2s at 192khz anyway. It accepts right-justified at 192khz.
Old 19th June 2018, 07:46 AM   #3
yogilla62 is offline yogilla62
Did you solve your problem?
I also bought this module but for CS4399, which is 32bit.
PCB with CS8421 is pre-configured for 24-bit output.
According to dataschet and placed tables, SAOF pin change is enough
with 4.02 k 1% to GND IS 24-bit date
at 8.06 k 1% to GND IS 32-bit date
Has anyone tried such changes?
Old 20th June 2018, 03:26 PM   #4
Markw4 is offline Markw4  United States
There is a datasheet for CS8421 at Mouser: http://www.mouser.com/ds/2/76/CS8421_F7-765043.pdf
It should tell you everything you need to know, or at least be a good start. Beyond that it would probably be a matter of understanding the I2S/PCM/TDM formats and interfacing to whatever to want to interface to.
Otherwise, if all that has been done and there are remaining questions or issues then maybe we could try to assist.
CS8421 ASRC configuration?Hide this!Advertise here!
DAC 2496 (AK4396) and CS8421 upsampling esgigt Digital Source 2 20th June 2014 12:46 PM
Upsampling DAC WM8741+DIR9001+CS8421 lduarte1973 Digital Line Level 2 30th April 2013 01:58 PM
Dac Help, WM8805 + CS8421 + Dual mono PCM1794 xslavic Digital Line Level 2 11th August 2012 04:25 PM
CS8421 upsampling in a DAC Wingfeather Digital Source 13 7th December 2006 01:21 PM
Any feedback on new CS8421 high-res ASRC? Wodgy Digital Source 19 25th October 2005 10:20 PM
