Audio GD DA-M1 R2R Dac Module
Old 26th May 2017, 05:30 PM   #41
Ben Mah is offline Ben Mah  Canada
Since I had the boards out of my system, I decided to do a bit of work and provide separate digital and analog power supplies. I used the TPS7A regulated supply to power the digital side of all four boards and then I added a TL431 regulated supply to power the analog side of all four boards. The supplies were independent of each other with their own transformers.
With this setup back in the system in place of my TDA1541a board, the harshness that I heard with only one power supply feeding both the analog and digital sides has disappeared. The sound is now very similar to my TDA1541a but I think the TDA1541a sounds a bit more rounded, maybe because it has a tube ouput stage since the chip output voltage is very low, or it could be because of other reasons. The DA-M1 boards have enough voltage output so an output stage is not required.
Old 26th May 2017, 06:01 PM   #42
rickmcinnis is offline rickmcinnis  United States
Ben Mah,
THANKS for your report! Now I must get to work on my boards.
It makes good sense to me, as it always seems to make a good difference, to have as many separate power supplies as possible.
Take care,
Rick McInnis
Old 10th November 2017, 11:07 AM   #43
rotulet is offline rotulet
Default DA-M1 newbee questions
Hi everyone!
I have some questions about the DA-M1 integration:
  • why it needs 2 power supplies (3.3V for analog and digital)?
  • does anyone have a part list for the output stage with nice and good components?
  • I intent to connect theses 2 (or 4, I am still undecided) beasts to a Raspberry PI via I2S. What will be the kind of driver I should use?
Thanks!
Old 10th February 2018, 12:19 AM   #44
hellokitty123 is offline hellokitty123  United States
How would this dac compare to standards like the Schiit Yggdrasil or other dacs offered by Audio-GD? Is it worth DIYing with this chip?
Old 10th February 2018, 07:36 AM   #45
I don't own any commercially produced dacs but I prefer my diy AD1865 and TDA1541a dacs over the DA-M1. I based this on long term listening and the DA-M1 didn't keep me happy in the long term. It is no longer in my system and will not be going back in.
Looking at their website it seems that Audio-GD has discontinued their Singularity 19 dac, which uses the DA-M1 module. Their latest R2R dacs use a new module. I wonder why?
Audio GD DA-M1 R2R Dac ModuleHide this!Advertise here!
Audio GD NFB15.32 late 2014 dac/amplifier modded with SEP caps for DAC supply lucpes Swap Meet 0 3rd February 2016 06:51 AM
DAC Audio-Gd NFB-28 fresher Swap Meet 0 6th February 2015 11:53 AM
Audio-GD Reference 1 DAC momomo67890 Swap Meet 2 22nd March 2014 08:23 AM
Audio-GD NFB-8 DAC (US version) Electro3000 Swap Meet 4 6th July 2012 03:05 PM
FS: Audio-GD NFB-3 DAC igor0203 Swap Meet 8 16th June 2012 12:37 PM
