!!! Xmos Problem !!! Dual AK4495S AK4495SEQ AK4118 DAC decoder XMOS USB w/LME49990
Pin 4 and 7 are totally wrong...can you please tell me why are 6 holes in regulator place...
make picture near regulator pins top side ...are they lm317..337?
underneath What is DC on both big capacitors?
What have you done with green?
Maybe colour code is not right ... disconnect primary and measure resistance from red to green and from black to green... sum from red to black must be equal as from black to green and green to red. Maybe they have mixed and you have 115v connection.
Jrc is producer like Texas instruments and Phillips...they all produce NE5534.
You get this opamp in all local electronic shop for almost nothing no need to wait for ebay delivery.
ne5534 - Search Results | Farnell UK
First you must solve right voltages on all pins.
The green is left unconnected and isolated. The resistance (Green 115v -- Red 230v)(on multimeter set to 200Ohm)
a) red to green 87.2
b) black to green 45.4
I have another transformer I have (115v Orange --230v Red) the readings:
a). red to orange 83.7
b).black to orange 43.0
In that case red and green are right wires and black is middle insulated wire.
China i got often problems with boards ...
1.disconnect secondaries from dac board except for audio part (yellow and brown)
2.connect green to neutral red to phase ... black isolated
3.measure DC on 2 big capacitors where you measure 50V DC
help tips Wioth U-208 Problem
Hi Ya All...
I Ralize this is quite an old thread nowadays....
I thought if i Could help Even One Person, Then ALL GooD :)
But have You asured that the powersuply setup matches the needs of
Witch i thought Strangley Stringent Listed in one of the PDF Files From The Xmos Site,
For the measly qf48 208 chip,, Wich If i remember Corectly from one of the countless PDF Files i Read & Plowed trough a Few Years back in my Resaearch back in those days, From The xmos Site....
The Point Being wich was one that stumped me a little bit,,
But if the PDF File Is Corect the U-208 Chip expects Full Power uP Within in 2o MilliSeconds,
i Canot remember if this was on all power pins (Probably Not)
It Maybe Clock/Timing related, Wich means u dont only need a good powersuply But you need a Fast One To.......
Bests Of regards To All Ya Hi_Fi Soul Lovin People.............
Reactions: 1 user
