Hearing strange distortions
that spike at 70khz is only there when generating a signal. there's absolutely nothing on the fft normally. I linked the wrong fft earlier, should have just been the noise spectrum, which is flat.
Have you tried hooking it up with usb with the power and gnd lifted?
I am not sure i follow lifting power and ground.
Please clarify.
can this help?
Hifime High-Speed USB Isolator
Though i'm still not sure i understand the mechanism by which the noise grass is entering from USB to the DAC with EXAU2I isolation in place.
The laptop was running on battery during the measurement.
