ES9018k2m Build Completed
Old 29th May 2018, 09:22 AM   #11
wchpikus is offline wchpikus
Mayby this dac ( sebre ) need master clock about 11MHz? If my clock is 2.82MHz i have 64fps..
This table shows how is clock fps and data..
Sample rate 44.1KHz..
Old 29th May 2018, 11:09 AM   #12
fluid is offline fluid  Australia
The Sabre doesn't need MCLK as it can run asynchronously.
I followed the guide at Hifiduino, I made a basic shield to attach the rotary trimmers etc. and connected a screen, rotary encoder with pushbutton to the arduino and loaded up the k2m code from hifiduino's website. Connected via i2c and I was able to control the DAC straight away, the only issue I had was related to the remote control from my apple remote as it was not recognised by the stock code, but that shouldn't be an issue for you if you just want audio.
If the bluetooth is outputting right justified data then you will need to change the register settings to get audio as it is not set to that as standard.
Register 10 sets that data here are some screen shots from the ES9018 manual that show the values they should be the same for the k2m.
ES9018k2m Build Completed-screen-shot-2018-05-29-8-55-43-pm-png
ES9018k2m Build Completed-screen-shot-2018-05-29-8-56-04-pm-png
This is from the hifiduino code where you can see the value that has been set for register 10. Changing that value should allow you to set it to right justified. There is another section in the code where the I2S type can be changed so if you look through it you may be able to make those changes elsewhere to work in with the menu structure.
ES9018k2m Build Completed-screen-shot-2018-05-29-9-00-06-pm-png
I haven't looked at this sort of stuff for a while and it was all new to me when I built this DAC so I can't offer much more help
File Type: png Screen Shot 2018-05-29 at 8.55.43 pm.png (97.4 KB, 271 views)
File Type: png Screen Shot 2018-05-29 at 8.56.04 pm.png (158.2 KB, 256 views)
File Type: png Screen Shot 2018-05-29 at 9.00.06 pm.png (107.9 KB, 151 views)
Old 29th May 2018, 11:32 AM   #13
I tryed this register 10 ( i know c) so i analized this code.
This registers not help.
So question is, what else is need to i2s decode?
Input source setup?
Other things?
Old 29th May 2018, 08:57 PM   #14
hi again
i read the data sheet and i am a litle crestfallen, how to read this.
I have to setup register 8 input as i2s.(arduinohifi has SPDIF)"
byte reg8=0x81; // GPIO configuration. GPIO1 set to DPLL Lock; GPIO2 set to input (for SPDIF).
default is 00010000 = 10 hex.
81 = 10000001.
ES9018-2M DS Rev 0.9_????
could someone explain what author has on main write this doc?
There is 15 values, from 4'd0 to 4'd15.
3:0 this is GPIO1 7:4 GPIO 2
15 = f hex = 1111.
i need 4'd9, so i have to setup for GPIO 2 =>10010000 ?? (1001=9).
this doc is strange
but away, software k2m051 do not work with i2s, only spdif..
all project is only for spdif, or setup is only for this input.
Old 30th May 2018, 03:52 PM   #15
ok i bought new dac and this works..but as Fluid said only left justified..
so default setup works without controller.
20180530 174314 — imgbb.com - data and ws
20180530 174753 — imgbb.com - new board
20180530 174802 — imgbb.com - ak dac
To remember...this board do not have resistors on input lines.
I2S and digital signal path - in-line resistors?
without resistors can't lock.
Old 30th May 2018, 05:01 PM   #16
ok old dac works, only left but with controller.
I will work with menu to change l and R justified.
20180530 190004 — imgbb.com
20180530 182119 — imgbb.com
Old 31st May 2018, 06:25 AM   #17
I'm not sure from your last few posts if you have it working or not, but I can select spdif or i2s with the hifiduino code from the menu and it works fine.
Register 8 sets the input as you say and register 10 the type of data to decode.
From line 905 onwards in the k2m051 code you can see the case switches for the different input options in the menu these change both registers to adjust the settings.
Old 31st May 2018, 07:47 AM   #18
Yea, i had some other problems with this dac board and this post i wrote to fast
Now i see what i had to correct (add resistors on i2s lines ).
Now works, but i have some strange things.
After power up controller stops on the start message, i thing the es is not ready yet.
Did you have the same?
When i wait some time without power on all works after power on.
I'll check it to next step.
The first add RJ to menu.
Old 31st May 2018, 10:42 AM   #19
I can't remember if the dac needed to be powered up before the controller or the other way round. I did have a similar issue but it has been a long time since I switched my DAC on to know.
Most arduino's have inbuilt pull up resistors so strange you would need extras.
Old 31st May 2018, 10:54 AM   #20
I wrote resistors on the i2s line not in arduino (dac boards has pullup resistors on i2c line).
Without resistors on i2s line i have oscilation when digital level changed, this resistors eliminate this isue (30ohm serial on clock,ws,data lines).
After added this 30ohm signals looks better (no oscilations) and dac lock to signal.
ES9018k2m Build CompletedHide this!Advertise here!
Pass B1 CLONE build completed and happy omishra Pass Labs 12 30th October 2012 05:23 PM
Completed build, for inspiration.. Elbert Subwoofers 14 2nd November 2011 09:00 PM
Completed LM1875 Stereo build bobsagat666 Chip Amps 12 15th July 2011 07:08 PM
First build completed tonga Solid State 2 18th February 2005 10:26 PM
