affordable dsp - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th July 2016, 12:00 PM   #1
Default affordable dsp
I'm looking for a cheap active filter for my electrostatic loudspeaker and magnetic woofer. (2 way system) I think it will be the easiest option to go active and I'm considering ditigal. I've read about MiniDSP which seems an affordable system.
I'm just not sure how sound quality is affected by this system. I don't have my own seperate ADC / DAC so for simplicity I prefer the integrated ADCs / DACs. Would they make an audible difference compared to for instance a simple op-amp based active filter?
I'm aware of the 2x4 HD version which has a digital input, but if I want to use an analog source like a turntable the signal still has to be converted multiple times. Would that be audible?
As long as the benefits of dsp filtering outweigh the disadvantages I will be happy with the compromise.
Old 28th July 2016, 05:42 PM   #2
The 2x4 also has a set of stereo, analog inputs. Note that the 2x4HD doesn't have a volume button, so you'll have to get a remote to do volume adjustment and source selection. For a turntable, you'll still need a RIAA. Theoretically, you can do the RIAA eq in the dsp, but you'll have to amplify the signal a good deal to make it useable first. It's simpler to just get a RIAA for the job.
Johan-Kr
Old 10th August 2016, 03:14 PM   #3
Thanks for your reply. I decided to go "one way": I just keep using my electrostatic loudspeaker without the addition of a woofer.
But I still need do damp the resonance at 50 Hz because it creates a very frustating distorted sound and I want to do some equalizing as well. (shelving filter)
What would be a cheap and good solution? I'm considering minidsp 2x4 or 2x4 hd, would the hd version give different sound quality or would sound quality be equal to the 2x4 version?
I would think I don't need the extra time domain functionality of the hd version as I decided to go "one way".
Old 11th August 2016, 03:08 PM   #4
If the selection is between the 2x4 and the 2x4HD, go for the 2x4HD - it is better.
If you use this, you can add a woofer section later.
If you only want eq, you can go for the OpenDRC AN, which has balanced inputs and outputs. This is one stereo input and one stereo output. https://www.minidsp.com/products/ope...ies/opendrc-an
Johan-Kr
HTPC DSP versus dedicated DSP platforms for loudspeakers diyaudnut Digital Line Level 16 21st June 2016 08:13 AM
Affordable 2 way potstip Multi-Way 3 28th December 2014 01:28 PM
Any affordable DSP solutions for FIR/equalisation? spot Digital Line Level 2 8th October 2011 11:36 AM
RS-232 cable for DSP-Amp Digisynthetic DSP-1400 Sabbelbacke Parts 0 9th May 2009 10:33 AM
Copyright 1999-2017 diyAudio
