Adding 3db gain at differential opamp output? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th July 2016, 10:09 PM   #1
Default Adding 3db gain at differential opamp output?
I have an diy Sabre32 ES9018 with a standard data sheet op amp I/V converter and differential amp output
ess 9018 output circuit.pdf.
I need just 3db more gain to drive amp with 10x gain (F5) and my speakers.
Can I just reduce (parallel so no un-soldering needed on pcb)slightly the 470 ohm to 370 to gain the x1.4 voltage ratio I need for 3db?
What is the noise penalty for such an marginal increase in gain in a differential amplifier?
I have 17v rails for op amps so doubt that headroom would be an issue? I would prefer not to add another gain stage.
All comments welcome.
Old 26th July 2016, 10:15 PM   #2
Would this small adjustment require an adjustment of the output filter capacitor values or is the effect negligible? Thanks in advance for nay comments.
Old 27th July 2016, 02:03 AM   #3
diyAudio Member RIP
I'd say an I/V converter always needs more resistance for more voltage.
rgds, sreten.
Old 27th July 2016, 10:54 AM   #4
DF96 is offline DF96  England
Reducing the value of the 470 (R6+R11) will raise the gain to the unbalanced output, and possibly change the frequency response too. It will not affect the gain to the XLR output - for that you need to increase R1+R17. Unclear what you want to do.
Old 27th July 2016, 12:30 PM   #5
What does the "AGND" mean?
Is it audio ground, or analogue ground, or chassis/enclosure, or screen/shield of the XLR cable?
Can any of those "ground" options be interconnected?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th July 2016, 12:32 PM   #6
are the first two opamps the DAC?
i.e. they convert the digital to analogue,
or is the DAC conversion done before we connect the "external current mode" circuit?
regards Andrew T.
Adding a (variable) gain boost to this non-inverting opamp buffer circuit? audiovisceral Analog Line Level 65 6th February 2015 05:06 PM
Can I modify an opamp buffer to add 3dB of BSC? goody75 Chip Amps 7 21st August 2012 02:25 AM
THAT1646 DIFFERENTIAL OPAMP batteryman Digital Source 0 11th August 2011 06:10 PM
Throwing away open loop gain with an opamp near or at unity gain okapi Pass Labs 3 25th December 2009 02:23 PM
Tube differential input/buffer /w opamp output gainclone aletheian Chip Amps 2 23rd August 2005 08:36 AM
Copyright ©1999-2017 diyAudio
