Building Pavouk's Async USB to I2S
Old 5th May 2017, 10:30 AM   #21
lemon is offline lemon  Greece
Make a bath pool with isopropylic alcohol and let it into for 5 minutes. A toothbrush will help you.
Let it to dry in the air...the best cleaning procedure!
Old 5th May 2017, 04:50 PM   #22
Mayday is offline Mayday  Sweden
Project Horder & Blogger
Mayday's Avatar
I do use isopropylic alcohol, I lost the brush I usually use, waiting for the new ESD-safe one to arrive I use qtips.
A tip from watercooling and overclocking CPU's, coffee-filters are great to wipe of the isopropylic alcohol as they don't leave any fibres or particles on the wiped surface.
The more you learn, the more you realize how little you know...
My blog, go have a look
Old 6th May 2017, 08:32 AM   #23
JPS64 is offline JPS64  Germany
Hello,
has this board DSD capabilities?
JP
Old 6th May 2017, 09:29 AM   #24
Mayday's Avatar
Originally Posted by JPS64 View Post
Hello,
JP
Have a look at the links I posted in an earlier reply, I don't know if it does as I don't need it.
Old 6th May 2017, 10:15 AM   #25
Mayday's Avatar
Only the missing parts left to populate on the first board now:
USB-connector 74LVC1G80 and the LP2992AIM5-3.3.
The 2 color LED I'll populate just before the USB-connector.
Old 9th May 2017, 02:01 PM   #26
Mayday's Avatar
Now I only wait for some 5u goldplated USB-connectors before populating dual LED and the connector.
Old 16th June 2017, 01:39 PM   #27
Mayday's Avatar
First board populated and programmed
Old 17th June 2017, 12:34 PM   #28
Well done, Mayday!
Old 17th June 2017, 01:20 PM   #29
Mayday's Avatar
Well done, Mayday!
Thank you, that's kind of you to say
Old 3rd August 2017, 07:12 AM   #30
Mayday's Avatar
Can I connect a two line. 16 character display to this?
Building Pavouk's Async USB to I2SHide this!Advertise here!
PCM2707 to Pavouk AD1865 I2S DAC ...it will work? rinox Digital Line Level 6 25th January 2018 03:02 AM
Sonore Async USB-I2S interface with onboard OSF barrows Vendor's Bazaar 48 9th August 2016 01:35 PM
Building USB I2S Converter For TDA1541 DAC wandermatt Digital Line Level 2 27th March 2014 02:58 PM
Building USB I2S Converter For TDA1541 DAC wandermatt Digital Source 0 15th March 2014 05:41 AM
new async USB-I2S module Gluca Swap Meet 7 6th June 2012 06:05 PM
