Dual Mono DAC AK4490/AK4497
Old 13th July 2017, 05:35 PM   #341
Dimdim is offline Dimdim  Greece
Before we designed the dual mono board we did a test board with a single 4490, just to make sure that the design would work. That's the one shown on my blog.
A full presentation of the dual mono version with the accompanying arduino code is on my to-do list.. I'm waiting on a new set of controller PCBs, so as to do a full presentation. These boards are useless without an Arduino (or similar) controller.
http://www.dimdim.gr
Old 15th July 2017, 06:38 PM   #342
nounouchet is offline nounouchet  France
Ok
I am waiting for your presentation.
Is there a real sound difference between single and dual mono ak4490 solution ?
Old 15th July 2017, 10:54 PM   #343
That is really hard to tell, since my two test platforms are very different (different power supplies, different clocking setup, reclocking vs. no reclocking, different layout, 4-layer vs. 2-layer boards, and of course, different analog stages).
What I know for sure is that my dual 4490 setup as-is sounds a lot better than my single 4490 test board as-is, but that really does not mean a lot.
Old 17th July 2017, 12:21 PM   #344
Considering the price of the chip, do not be embarrassed !
Old 17th July 2017, 12:52 PM   #345
The price of the DAC chip is the least of our "problems" in these implementations.. the more expensive parts are the clock and the power supplies. Plus the output stages... But mostly the power supplies.
Old 17th July 2017, 01:20 PM   #346
it's what i mean...
Old 25th July 2017, 12:14 PM   #347
iggy111 is offline iggy111  Croatia
Hi guys, trying to upgrade the output section for AK4490 (diyinhk) dac. I use LME49720 now but want to try Sparkos discrete dual op-amps or transformers, but with transformers I don't know where to start. Any advice? Which trafo should I get, and which step-up ratio should I aim for?
Old 25th July 2017, 08:15 PM   #348
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
Originally Posted by iggy111 View Post
I use LME49720 now ...
try ADA4627 ... much better.
@Dimdim: thanks a lot for your efforts!
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 25th July 2017, 08:59 PM   #349
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
1:1
Regards Åke
Old 27th July 2017, 09:40 AM   #350
Don't want to hijack the current thread, I'll post my findings about transformers and discrete output sections when I have something to share
@UnixMan will try ADA4627 if I get my hands on it
@Ryssen thanks, I'll go read some more now
Dual Mono DAC AK4490/AK4497Hide this!Advertise here!
Dual mono DAC and splitting DOR and DOL danils Digital Line Level 0 13th February 2014 03:37 PM
S.houBed DAC 132db Dual MONO pcm1794 xslavic Digital Source 30 24th February 2013 12:36 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
Dac Help, WM8805 + CS8421 + Dual mono PCM1794 xslavic Digital Line Level 2 11th August 2012 04:25 PM
Dac or Dual-Mono Amps? Reference1042 The Lounge 2 9th March 2012 12:38 AM
Copyright ©1999-2017 diyAudio
