Dual Mono DAC AK4490/AK4497
Old 29th July 2016, 06:56 AM   #101
mtoc is offline mtoc
Banned
Originally Posted by Baka View Post
You need two AK4497 for that board.
lord, that's one 4497, the other chip is 4118.....
Old 29th July 2016, 07:37 AM   #102
Baka is offline Baka  Montenegro
Nope. Look at the picture carefully.
Old 10th August 2016, 06:51 PM   #103
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
Originally Posted by themystical View Post
Not many people building this DAC so I thought I would share my experience. I have separate super regulated power supplies for the Analogue 5V and the analogue 3.3V. Separating out the Digital 3.3V was not a huge subjective difference in SQ. However running the Analogue voltage at 6.8V was miles better. More clarity and density to the sound.
which kind of mods to the board have to be done to allow the usage of 7V?
In terms of op amps I have tried various including LM49990, LM47910, AD4489 etc The cleanest sounding is LM4990.
you should try the OPA1688 in there...
I would say that this chip is equal to or better than the Sabre ES9018Dual Mono DAC AK4490/AK4497
definitely way better, IMHO.
(at least for what I can tell from the implementations of the two that I have heard so far).
Originally Posted by Green77 View Post
Just finished a DIYINHK ak4490 board. With a standard 7812/7912 psu for op and a lm317 for 3.3v. On the 5v in i'm use a low noise psu set to 6.8v.
I use the xmos USB card from DIYINHK too.
Everything works, but the sound is really bright.
Anyone have the same problem with this pcb?
I have a simple "full-DIYINHK" setup (also with their low-noise PSU boards for everything). No brightness whatsoever.
BTW: the DIYINHK board does not provide a "decoupling" resistor on the OpAmp output... thus you must add a good ~100 Ohm resistor in series with the analog output!
That will make any OpAmp happier and will provide great SQ improvement.
In dual mono form this is one of the best sounding DACs I have heard.
is there a description of your setup somewhere? Or, could you describe how you have done that?
Well, i did use 6.8v where it say 5v.
Wait! Have you modified the board to separate the different supply? Without doing that, you can NOT apply more than 5V there!
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 13th August 2016, 09:49 AM   #104
themystical is offline themystical  United Kingdom
No mods required. Simply connect 7V instead of 5V
These are not available from the usual suppliers in the UK but I notice that they are very cheap and seem to have really good specs for a headphone driver op amp. Perhaps somebody could send me a couple?Dual Mono DAC AK4490/AK4497
Please see this thread - no mods required to the DIYinHK boards.
Dual Mono wiring for a Vout DAC
https://r.tapatalk.com/shareLink?url...6&share_type=t
Sent from my iPad using Tapatalk
Old 13th August 2016, 11:21 AM   #105
UnixMan's Avatar
There's something strange... this is the answer I've got directly from DIYINHK customer service:
3. please notes the max voltage of AVDD is 5V, maximum VDDL/R is 7V, you will need to cut trace on our PCB if you want 7V to VDDL/R.
Supplying 7V to the +5V input of an unmodified DIYINHK board will provide 7V also to the AVDD line... doing so will likely damage your DAC chip.
you can get 'em e.g. from Mouser UK: http://www.mouser.co.uk/ or even order directly from TI.
just add the resistor in series with the analog outputs, wherever you see fit... (also right on the board output connectors, or just before them). They must be outside of the OpAmp NFB loop, but before any cable connection. Their purpose is to "shield" the OpAmp output (and its NFB loop) from capacitive loads (such as cables).
Thank you. That's for what regards the analog out... which is the easy part. But what about the digital in?
How have you connected the USB interface to the two DAC boards I2S inputs to get dual-mono operation?
Old 13th August 2016, 01:18 PM   #106
jdlayman is offline jdlayman
Disclaimer: I don't have one of these boards yet, but looking at a picture of the board from hifiduino, I don't see any trace connecting AVDD and VREF. I see a connection between AVDD and DVDD as well as VREFR+L and VDDR+L. Am I missing something or is it possible the DIYINHK support team got the pins confused in their response?
Sent from my iPhone using Tapatalk
Old 13th August 2016, 02:59 PM   #107
UnixMan's Avatar
mmmh, I'll have to check the board (will also ask them again), but likely you're right: looking at the Ak4490 data-sheet, the AVDD supply voltage allowed range is 3.0V to 3.6V... thus it should be connected to the 3.3V supply line, not to the +5V... (unless it is connected to it through some divider, but that sounds unlikely).
Old 13th August 2016, 03:16 PM   #108
DiyinHK is privy to the same data sheet as you and I and I looked at the Datasheet and the board quite carefully before I upped the voltage to 6.8V.Dual Mono DAC AK4490/AK4497
Old 13th August 2016, 04:03 PM   #109
Also the i2s signals are simply paralleled to the two mono boards. Some people would argue that you need 10-30 Ohm resistors in series with each connection but I don't use any.
Old 13th August 2016, 05:03 PM   #110
UnixMan's Avatar
well, but then each DAC/board will still be processing both (different) audio channels. That's not "dual mono"... this way you're just using two DACs in parallel.
To get real "dual-mono" - that is, to use both channels of one chip/board for one audio channel (say, R) and the other board for the other channel (say, L) - you would need to act on the I2S signal so to send only "L" samples to (both channels of) one board and only "R" samples to (both channels of) the other.
Am I wrong? Click the image to open in full size. Is there anything I'm overlooking?
Dual Mono DAC AK4490/AK4497Hide this!Advertise here!
Dual mono DAC and splitting DOR and DOL danils Digital Line Level 0 13th February 2014 03:37 PM
S.houBed DAC 132db Dual MONO pcm1794 xslavic Digital Source 30 24th February 2013 12:36 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
Dac Help, WM8805 + CS8421 + Dual mono PCM1794 xslavic Digital Line Level 2 11th August 2012 04:25 PM
Dac or Dual-Mono Amps? Reference1042 The Lounge 2 9th March 2012 12:38 AM
