CSR8645 Bluetooth 4.0 AAC APT-X Module / Baseboard
Old 15th February 2016, 12:45 AM   #11
doctormord is offline doctormord  Germany
doctormord's Avatar
Pretty much final.
CSR8645 Bluetooth 4.0 AAC APT-X Module / Baseboard-bt_5050-jpg
2Vrms Line-Driver (TI DRV603) with MFB-Filter (25kHz passband) and cap-free output
Ground-Loop-Breaker-Resistor implementation
5 buttons
GPIO-Extender/Breakout-Connector on bottom side
I2S/SPI with 1.8V -> 3.3V level-shifter
USB-Audio
Diff-In
Diff-Out
SE-Out
Power-Options:
Option1:
Flybuck 950kHz (6-42Vin -> 3.3Vdigital + isolated 3.3Vanalog)
Option2:
Flybuck-bypass via HV-LDO (5-36Vin -> 3.3Vdigital + nonisolated 3.3Vanalog),
USB 5.0V
Old 15th February 2016, 02:20 AM   #12
orto is offline orto  United States
orto's Avatar
Wow, that is a luxurious ride for those CSR chips. If you ever make a run of these boards I would be interested. I've been trying to make a jig so I can program these chips, it would be nice to be able to just solder them onto a board.
Old 15th February 2016, 03:06 AM   #13
doctormord's Avatar
Yeah, the board actually features different options to populate, as I haven't evaluated what level of clean power and isolation is really needed. So half of the stuff is optional. There's also a lot of capacitance which may can get consolidated. But better having all options first than doing 3+ iterations of the design, being always behind the demand. I'll surely do a small 10 PCB batch.
Sent from my A10 using Tapatalk
Old 6th March 2016, 12:16 AM   #14
Dmtr is offline Dmtr  Russian Federation
Hey. Can I connect the module csr8645 via i2s for external dac? So what to do?
Old 7th March 2016, 08:59 PM   #15
DeeFiler is offline DeeFiler  Russian Federation
That's really a fine job with that PCB for CSR chip. Got luck of testing the board yet?
One question, if you allow, doctormd - what is the value of R4 and R11 resistors on your diagram in the LM358 input?
Old 24th March 2016, 10:43 AM   #16
wchpikus is offline wchpikus
Hello
I have this module too, and i thing about setup i2s in my project.
Now questions:
- how to connect to this device (using special programmer?)
e.g.
CSR uEnergy SPI Programmer Board Kit - Broadband
- is it possible to connect via uart?
- how to or is it possible to setup GPIO to e.g led driver, key or different usage?
- anybody have sdk for this module to write some firmware?
Old 22nd April 2016, 09:22 AM   #17
doctormord's Avatar
Haven't tested yet, but it is supposed to work like so.
The resistor where meant to symmetrize the inputs and are optional. The concept is skipped in the actual implementation as i use a diff/se linedriver.
CSR8645 Bluetooth 4.0 AAC APT-X Module / Baseboard-board_top_960-jpg
Old 22nd April 2016, 09:27 AM   #18
Nice.
I stiil working to setup this module streaming via i2s, no results.
A tested wt32 and working ok, csr8645 still silence on i2s ports..
Old 22nd April 2016, 12:07 PM   #19
doctormord's Avatar
Have you checked for any clock signals on the data lines?
The WT32 should work with the same tools, so you might compare the set PSKEYs.
Old 22nd April 2016, 12:32 PM   #20
I have connected analyzator to spi and i see transmision, when switch to ground PCM pin, no signal on all spi/pcm.
Shared clock-clock, miso-data, cbs-sw, correct?
I got all spi pins on analyzator.
CSR8645 Bluetooth 4.0 AAC APT-X Module / BaseboardHide this!Advertise here!
Bluetooth module help chemacky Construction Tips 0 15th May 2015 06:40 AM
3 Pcs - NIB - APT-X Bluetooth 4.0 Audio Receiver aterren Swap Meet 0 24th March 2015 02:06 AM
bluetooth module to amp ( ask ) miftah Digital Source 1 15th August 2014 10:16 AM
Sure Electronics Apt-X Bluetooth board volume delay? Anyone else? johnnygrace Parts 3 27th July 2014 03:44 PM
Power supply to bluetooth module Luciano020 Power Supplies 5 30th October 2013 05:36 PM
