freeDSP main thread
freeDSP main thread
Old 9th December 2017, 02:02 PM   #21
JayShoe is offline JayShoe  United States
What would you recommend? We're always open to suggestions :-)
Maybe a link on each project to the relevant discussion. Or maybe a page for each project with links to each related site. The table is a teaser, but the information then requires some searching. For example, when there are no "KiCad" or project links to a github repository... Where is any of the details on said project? Some of the projects say "help wanted"... Where do we go to find out the status of that project? How can we help?
Again please accept my criticism with full respect for your AMAZING WORK! :-)
Old 9th December 2017, 08:55 PM   #22
I'm into the research of trying to figure out how to make a USB Soundcard, with a built in DSP. So the idea is to have USB OTG (slave device) connected to a PC, playing audio through USB Audio, into the DSP, processed, and then outputted through to the DAC.
I think maybe the Pi Zero and the PiDSP can be the base hardware for this project. The Pi Zero can be set to USB OTG mode (link). The PiDSP can connect to the Pi Zero 40 pin header. The PiDSP Getting Started Tutorial says, "I2S input and output" can be accessed via the header (with or without Master Clock). And so the next question is how to turn the Pi Zero into a USB Soundcard Device inside of Linux, and then send the USB Audio to the I2S of the Pi Header through to the DSP.
The name of what I'm trying to do is called "G_audio" using the linux gadget functionality. Turning the PiZero into a USB Gadget g_audio.
Old 9th December 2017, 10:18 PM   #23
A nice guide regarding USB Gadgets in linux and the current "ConfigFS for USB gadgets" functionality that would be required in the pi Zero.
Raspberry Pi Zero as Multiple USB Gadgets << irq5.io
Old 18th December 2017, 12:49 PM   #24
IPv6 is offline IPv6  Germany
Hi!
I ordered some FreeDSP PCBs from china and got a lot of them left over.
I would give them away for rounded up shipping costs, doesn't matter if you want 1, 2 or 5. Would be a shame to just throw them away.
Available PCBs are:
- CLASSIC SMD A
- UNBAL OUT x8
- UNBAL IN x8
Just send me a message.
_____________________________
Ich habe ein paar FreeDSP Platinen in Fernost machen lassen und habe nun einige Platinen übrig. Diese würde ich gegen aufgerundetes Porto abgeben. Wäre schade, wenn ich sie wegschmeißen müsste, für so viele Platinen habe ich einfach keine Verwendung. Aber Einzelstücke machen lassen ist ja leider teurer als gleich 10 Stück zu nehmen.
Verfügbar wären:
- CLASSIC SMD A
- UNBAL OUT x8
- UNBAL IN x8
Bei Interesse einfach eine kurze Nachricht schreiben.
Gruß
Old 3rd January 2018, 04:40 PM   #25
irs20957 is offline irs20957  Russian Federation
Hi all!
I have FreeDSP Classic SMD A v 1.0
does not work, white noise at the outputs.
What to do?
Need shematic diagramm, to install components correctly.
GitHub - freeDSP/freeDSP-CLASSIC-SMD-A: SMD Version with classic expansion header not correct.
Old 10th January 2018, 03:26 PM   #26
Hi!
So I'm currently soldering one of my CLASSIC SMD A Boards, everything seems to be fine so far.
But which audiojack connectors are used in this project (they are also used in the UNBAL IN x8 and UNBAL OUT x8 projects)?
The footprint says "alexmod:JIS_C_6560_3.5" but which part is it? Where do I get it?
There also seems to be no information about the opamps, could anybody tell me which ones to use for the UNBAL OUT x8 and FreeDSP CLASSIC SMD A?
At the FreeDSP homepage the projects are marked as "READY" or "TESTED", so someone already should have build them, right?
Best regards from germany!
Old 14th April 2018, 11:20 AM   #27
alex6679 is offline alex6679  Austria
I have some questions about the freedsp classic smd b and its expansion ports:
Can the AES/Spdif input expansion, which is designed for freedsp classic, also be used with the classic smd b version?
I know that the freedsp classic smd b provides 12V power supply and the expansion board needs 3.3V. But I think a dc/dc converter could solve this problem.
Aside from that, would the AES/Spdif input board work if one connect the corresponding bclk, lrclk, mclk and the data line of freedsp and the AES/Spdif input board?
I would be glad about any help.
best regards
Alex
Old 14th April 2018, 01:38 PM   #28
I had a look at the manual (https://d3uzseaevmutz1.cloudfront.ne.../CS8422_F2.pdf) of the Cirrus Logic CS8422, which is used at the SPDIF input board. At the board the MS_SEL pin of the CS8422 is connected to GND by means of a 32.4kohm (R8) resistor. According to the manual the CS8422 is the running in master mode (table on page 42) at sdout1 output. If the board is used in combination with the freedsp smd b, it should probably run in slave mode? Should R8 be changed to e.g. 127kohm in order to run the CS8422 in slave mode?
Best regards
Old 9th May 2018, 02:07 PM   #29
amcsx4 is offline amcsx4
Default Rephase
Would any of your boards be compatible with RePhase?
Old 9th May 2018, 04:06 PM   #30
SubSoniks is offline SubSoniks  Wales
ADAU1701 works with Rephase out of the box so to speak, limited amount of taps available though <500.
freeDSP main threadHide this!Advertise here!
freeDSP - an open source 2-in 4-out digital crossover board CharlieLaub Digital Line Level 331 16th April 2018 01:20 PM
freeDSP V2.0 (ADAU1452) developement thread Pitrsek Digital Line Level 245 30th March 2018 02:26 PM
Should a person who starts a thread have quasi moderator status on their own thread? erin The Lounge 15 23rd October 2012 10:41 PM
AIKIDO: Main Thread??? brianco Tubes / Valves 3 17th January 2008 04:44 AM
